Need help to identify noise
Old Sep 10, 2015 | 09:16 PM
sawduster's Avatar
Default Need help to identify noise
I'm hoping someone can help identify the source of this noise I am hearing. I've attached a short video of the sound - it sounds like someone blowing air over an open coke bottle. It's definitely connected with the rotation the wheels, probably the right rear wheel. Also:
- I only hear it after the car gets wet, either when it rains or I wash the car;
- I hear it for the first 10 seconds after the first start and drive of the day, then it goes away.
I'm thinking maybe a wheel bearing, but I would think that would persist and get worse at higher speeds, which doesn't happen.
My other thought was something connected with the parking brake?
File Type: mov
Old Sep 10, 2015 | 11:13 PM
Bud Tender's Avatar
Maybe the carrier bearing on the rear drive shaft.
Old Sep 10, 2015 | 11:54 PM
dwclapp's Avatar
Does the noise change when you tap the brake pedal or pull up on the e-brake handle?
Old Sep 11, 2015 | 01:32 PM
sawduster's Avatar
Default Wheel noise
It rained last night (quite a bit) so I had a chance to try out these tests this morning. Tapping on the brake didn't make any difference. Pulling up and releasing the e-brake lever seemed to stop the noise (I'm pretty sure about this but will try again to confirm it).
Old Sep 11, 2015 | 07:15 PM
innzane's Avatar
That is an odd one. But I did not hear the coke bottle sound in the video.
Could it be the brake wear indicator starting to rub?
Old Sep 11, 2015 | 10:02 PM
sawduster's Avatar
The noise is mainly in the first half of the video, before the sounds of the doors locking.
I'm not sure this makes any difference, but I park the car at a slight incline, with the front higher than the back.
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
