Need Help Locating Canister Vent Solenoid
Old Jan 1, 2010 | 10:02 PM
jonzyjones11's Avatar
Default Need Help Locating Canister Vent Solenoid
I am having trouble locating the Canister Vent Solenoid. Part #C2S8605, I was told it was located directly above the rear differential. Cannot find it please help, pictures would be great!!
Having trouble filling it up with gas looking to replace that part.
Any thoughts/comments would be great!
Old Jan 2, 2010 | 07:46 AM
Thermo's Avatar
Veteran: Navy
Jonzy, the vent canister has nothing to do with filling up the vehicle. All the canister does is collect the unused vapors. What you want to look at is the small rubber tube that runs next to the filler tube. I bet you will find that it is pinched somewhere and not letting the displaced air to escape. That will build up pressure inside the gas tank and make the fuel pump think that the tank is getting full.
Old Jan 2, 2010 | 10:01 AM
Brutal's Avatar
thermo he is correct, the vent solenoid on the end of the charcoal cannister IS there to allow vapor pressure to escape when filling with gas. If it sticks closed the vapor heads out the tube you speak of and the filler neck and shuts off the nozzle. A worse senario is if the vent valve on the top of the tank is bad, you have to drop the tank to replace and I dont even remember if it is a servicable part or you need a tank replacement
Old Jan 2, 2010 | 11:03 AM
Burtal -
Have you replaced the canister before? I took it to my local Jag dealership and they replaced the purge valve Part #C2G2403. The reason I took it in the first place was for my check engine light which was code P0443. They reset the light and I was on my way, 30 miles or so it came back on. Obviously it wasn't the Purge Valve that was causing the fuel cut off...
Old Jan 2, 2010 | 08:47 PM
Thermo's Avatar
Veteran: Navy
Brutal, I thought that the vent solenoid was there only to prevent getting too high of a vacuum inside the gas tank. Huh, you learn something new every day.
Old Oct 27, 2011 | 08:43 PM
dyob's Avatar
newbie, cant find a button to post
aarahim
Aug 31, 2021 11:04 AM
danke
Mar 3, 2016 10:57 AM
swetnK
Sep 23, 2015 10:49 AM
bowhunter72
Sep 21, 2015 10:14 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
