Need Help on my X-Type
Old Jun 7, 2017 | 07:38 AM
Namo's Avatar
Default Need Help on my X-Type
Hello guys, please i need help to resolve an issue i am having with my Jag.
When i start my car in the morning it misfires and the engine does not run smooth at all. i got error codes P0191, P1316, P0300. I noticed whenever i turn on the engine when it is still hot or has been driven, the engine does not run rough. Also sometimes the codes clear on its own and i dont see any code when i scan. Also sometime when i am going up hill it stutters.
2002 Jaguar X Type
3.0 Liters
Old Jun 7, 2017 | 08:22 AM
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model and members here with the same model will be able to help.
Old Jun 11, 2017 | 09:42 AM
cujet's Avatar
I recently changed the PCV hose and the brake booster hose, along with the spark plugs.
Solved my start up misfire, completely.
As crazy as it sounds, I also found that Marvel Mystery Oil added to the gas also helped. At first I thought I had a sticking valve, as the misfire was only one cylinder and the plugs were not old.
In any case those 2 parts were leaking vacuum and causing the misfire.
Other Areas
Nov 2, 2025 11:42 AM
idahoskiguy
Dec 23, 2016 11:13 PM
Thang Nguyen
Dec 8, 2016 09:42 AM
MardyFreeman
Nov 5, 2016 08:11 AM
David12345
Oct 6, 2016 12:18 PM
