Need rim help
Old Jun 18, 2011 | 07:06 PM
gragner66's Avatar
Default Need rim help
I got a new set of SSC Style 28 in chrome rims went to get them installed and the studs were to short that were on the car. Does anybody know how to get longer studs for Xtype. The rims fit fine but not much thread on the nut holding them on here a pic of it
Old Jun 18, 2011 | 07:35 PM
southernjag's Avatar
WOW 28"!!!!!! That's HUGE!!!!!
Old Jun 18, 2011 | 09:18 PM
Thermo's Avatar
Veteran: Navy
gragner, are you using the correct lugnuts for the rims. You will not be able to use the Jag factory nuts, but will have to go with an aftermarket acorn nut. Look into the rims and verify the type of nut that is needed. I bet you will find then that the studs are plenty long.
Old Jun 18, 2011 | 09:37 PM
exexpat's Avatar
Are you sure? You need minimum 6-to-7 360 degree turns with conical seat lugs. Jaguar studs are annoyingly short, but we have stupid UK-only countersunk lug nuts on our cars. You can get longer ones from Pep Boys for about $1.50 each.
Old Jun 19, 2011 | 06:14 AM
gragner66's Avatar
yes we had aftermarket nuts but didint actually try to tighten because studs looked so short according to mechanic. o'reileys had longer nuts but didnt fit in the holes. mag shop is ordering nuts that are from rim company hopefully they will work...by the way i wish they were 28's thats just the style# . ill try the 6 to 7 turn today and see if i can get that many
Old Jun 20, 2011 | 11:01 AM
mohrd's Avatar
You'll need something like these for the aftermarket wheels...
Old Jun 20, 2011 | 12:41 PM
exexpat's Avatar
Good point and good find. I forgot about those.
Old Jun 20, 2011 | 05:43 PM
gragner66's Avatar
i hope that is what the shop is sending me this week
Old Jun 21, 2011 | 02:43 PM
Tec Nine's Avatar
that's weird i always thought the stud length was normal
Old Jun 21, 2011 | 06:41 PM
exexpat's Avatar
They are about 10mm shorter than most. If the wheel backpads are over 16mm thick from the bottom of the cone seats, it gets a little sketchy. Likewise, shaving wheel pads to less than 9mm starts to be too short for the factory lugs.
Basically Jaguar doesn't want you to pop through the stainless lugnut end caps, so they keep the studs short.
robbing
Mar 5, 2024 10:51 AM
Larry-Cleveland
Feb 9, 2019 03:17 PM
Marque
Oct 11, 2015 05:59 PM
Marque
Sep 27, 2015 10:28 PM
