O2 Sensor Replacement: #2 sensor, bank 2
Old Nov 8, 2017 | 01:14 PM
Jag4's Avatar
Default O2 Sensor Replacement: #2 sensor, bank 2
Hello forum,
Sanity check - I believe sensor 2, bank 2 is a downstream sensor. Located closest to the radiator.
I purchased Denso's downstream sensor part number 234-4798.
Is this correct?
Thanks forum!
Old Nov 8, 2017 | 01:24 PM
Mark Murphy's Avatar
That's the one
Old Nov 8, 2017 | 05:27 PM
avern1's Avatar
As Mark said correct on both counts. When you get ready to unplug it you will find you have to remove the battery and box ,the plugs are mounted under the battery support plate.
Old Nov 8, 2017 | 09:39 PM
Jag4's Avatar
Great. Thank you gentlemen.
