Fan running
Old Nov 8, 2017 | 01:30 PM
queenvir23's Avatar
Default Fan running
2007 jaguar x type fan stays running while car is on
Old Nov 8, 2017 | 03:08 PM
Thermo's Avatar
Veteran: Navy
queenvir23, the fan can run for a few different reasons, even when the motor is ice cold. To see if you really have a problem or not, let the car sit for a few hours to ensure the motor is cold. Next, get into the driver's seat. Turn the ignition of the car to the RUN position (DO NOT start the car). Let the heat-A/C unit come on and then turn it off/ensure it is off. Now, start the car. Open the hood and see if the fans are running now. They should not be. If they are, then most likely you have a bad fan module and it will need to be replaced.
Odds are, what you are experiencing is that you have the defroster running. The defroster uses the A/C system to remove the moisture from the air, to make clearing of the windshield faster and more efficient. When the A/C system runs, the car will run the fans relative to how much cooling is needed (little A/C need, fans run slowly, lots of A/C needed, fans run in fast).
Old Nov 9, 2017 | 08:40 AM
Alfadude's Avatar
Have you checked that your coolant level is not low?
Digital Will
Feb 21, 2026 05:58 PM
andyXJR
Oct 7, 2016 02:06 PM
Joearch
XE ( X760 )
Oct 6, 2016 09:14 AM
Oct 30, 2006 11:24 PM
Oct 4, 2006 12:41 AM
