OBD2 Port
Old Mar 17, 2015 | 03:38 PM
curtizb's Avatar
Default OBD2 Port
Have an odd problem with my OBD2 reader/ port. I am getting power from the port and I can connect to the reader with Torque (full ver) but when I try to read the codes it says that it is not connected to the ECU. I know the reader is fine as I have tried it on another vehicle. The battery in the car needs to be replaced so I am having to jump the car, so not sure if that may be related to the issue. The green and yellow lights are blinking away on the OBD2 adapter and I know I am connected to the adapter itself. Any suggestions on maybe some fuses to check. I will be swapping out batteries tomorrow. On a side note I did have a fancy 800 dollar scanner on the car which read the codes, but at the time I did have a brand new battery in the car that I was using to test a few things. I keep thinking its something to do with the battery....
Thnx.
Old Mar 17, 2015 | 03:41 PM
Thermo's Avatar
Veteran: Navy
curtizb, I am suffering from the same sort of issue with my reader and I have found that if I unplug it and re-plug it in, sometimes it will make it work. It is sounding like you have a pin somewhere that has been pushed in.
aarahim
Aug 31, 2021 11:04 AM
ziondio
Oct 1, 2015 01:48 AM
reb1999
Sep 25, 2015 10:00 AM
bigmikeyt
Sep 14, 2015 12:06 PM
