ODB fault code P0105 Manifold Absolute Pressure sensor
Old Feb 20, 2018 | 02:33 PM
Jag4's Avatar
Default ODB fault code P0105 Manifold Absolute Pressure sensor
Hello members,
A couple weeks ago I noticed a sudden drop in my gas mileage. I was about to check the e-brake when I got the above code, P0105.
I ran ODB-II real-time tests and here are those results:
TID: $0a CID:$11
TID: $22 CID:$11
TID: $04 CID:$11 (this one is new)
(Pretty sure some of that isn't needed)
I have replaced all O2 sensors except the one closest to the passenger firewall, which requires a special tool - I guess - cuz I can't get to it - for now.
My question: Should I start by replacing the MAS? Any other considerations?
Thank you members.
Chris
Old Feb 20, 2018 | 04:41 PM
avern1's Avatar
The code indicates a bad MAP sensor or a bad wire between the sensor and the ECM. See the attached info. I would first check the wires but most likely the sensor is bad.
Attached Thumbnails ODB fault code P0105 Manifold Absolute Pressure sensor-map-sensor.jpg   ODB fault code P0105 Manifold Absolute Pressure sensor-map-sng.jpg
ryejag
27
Sep 21, 2021 10:16 AM
car5car
Feb 7, 2016 12:51 PM
nsl1
Dec 7, 2014 07:47 AM
Blue Lion
Jun 20, 2012 02:16 AM
Jag4.0
Jul 14, 2008 03:38 PM
