Oil Change????
Old Jul 30, 2008 | 08:01 PM
Striker27's Avatar
Default Oil Change????
Looking at doing this soon.
Any recommendation on the procedure or recommendations???
THANX
Old Jul 30, 2008 | 08:38 PM
Dennis's Avatar
ud
Default RE: Oil Change????
get 7 qts of Oil and new oil filter from dealer..I use Castrol Syntec 5w30
Old Jul 30, 2008 | 08:39 PM
Dennis's Avatar
ud
Jack up front of car or use ramps..use proper safety
Old Jul 30, 2008 | 08:41 PM
Dennis's Avatar
ud
13MM wrench to remove drain plug..(Righty tighty, lefty loosey)
You may have to remove the TC cooling air scoop (one 10MM bolt)
Dennis's Avatar
ud
a band filter wrench to remove old filter..
Old Jul 30, 2008 | 08:43 PM
Dennis's Avatar
ud
Drain old oil and prefill new oil filter with fresh oil before installing.. smear a little oil film to filter rubber gasket too.
Old Jul 30, 2008 | 08:44 PM
Dennis's Avatar
ud
reinstall drain plug after it has dripped about 30 minutes..and lower car to level again
Old Jul 30, 2008 | 08:45 PM
Dennis's Avatar
ud
Add including what you put in filter, 6 qts and run engine for a few minutes and check oil level..
Old Jul 30, 2008 | 08:46 PM
Dennis's Avatar
ud
Top up oilto full mark on dip stick..Mine takes 6.8 qts all together.
Old Jul 31, 2008 | 09:31 AM
mr.xtype's Avatar
I use mobile 1 synthetic with the mobile 1 synthetic oil filter. Best prices I have found were from Pep Boys in the USA, I am Canadian so every time I drive down to the states I buy 2 jugs and a filter. Also I noticed Sonic Delta car washes do a full synthetic mobile one oil change for about $65 which is about the same costs as parts but then if your pricing it out you are basically getting labour in for free. I have never done this as I just found out the price recently but maybe next time I will.
Old Jul 31, 2008 | 12:05 PM
DZtt's Avatar
Isn't the x-type jaguar oil filter the same as a ford/motorcraft oil filter? If so does anyone know the part number?
Old Jul 31, 2008 | 01:23 PM
Dennis's Avatar
ud
Mann makes them for Jaguar OEM..
http://www.bizrate.com/automotivepar...__start80.html
Old Aug 3, 2008 | 02:10 AM
Grim001's Avatar
Anyone using the oil filters with Teflon in them? Wonder if it helps any, for cars over 70K? or what about Teflon additives for synthetic?
Old Aug 3, 2008 | 12:12 PM
queenmb's Avatar
Im confused. Is it okay to put synthetic oil in the V6 or no?
Old Aug 3, 2008 | 12:54 PM
Dennis's Avatar
ud
Yes it is okay..No problems, in fact you may see better mileage.
Old Aug 3, 2008 | 01:12 PM
queenmb's Avatar
Thanks Dennis
Seeing that Jaguar does not approve synthetics in the V6had me a little scared
especially since I had already put synthetic oil in mine
Old Aug 3, 2008 | 01:55 PM
Dennis's Avatar
ud
It's a long story..but that was in the simplest terms.. a mistake on Jaguar's part..Had everything to do with the free olil changes they gave away at one time..So Sythetics are fine
Old Aug 4, 2008 | 10:29 PM
Oldengineer's Avatar
The Motorcraft oil filter is an FL400S - I Believe.
Regards:
Oldengineer
Old Aug 5, 2008 | 07:11 AM
Thermo's Avatar
Veteran: Navy
The Motorcraft filter is the FL-420S. Chris "Thermo" Coleman
Old Aug 6, 2008 | 04:21 PM
Striker27's Avatar
Wow lot of info here!!!
I was not really expecting this info with such a simple post.
