Oil leak -manual transmission
My 09 2l diesel manual appears to be leaking oil from somewhere around the selector mechanism, the bit that the cables fit to and I'd partially underneath the LH engine mount. The side of the diff is wet around the driveshaft area but the seal itself seems ok, there is no oil spray to indicate the seal is leaking.
Has anyone had similar problems and what is the fix?
jag79
Feb 2, 2011 10:55 PM
