over pressured cooling system
Old Oct 28, 2015 | 03:48 PM
Bryan Fisher's Avatar
Default over pressured cooling system
Got a question what would cause my cooling system to build up
So much pressure it blows a radiator
Old Oct 28, 2015 | 04:31 PM
hlgeorge's Avatar
My guess is just a defect in the radiator.
Old Oct 28, 2015 | 04:35 PM
Mikey's Avatar
Leaking cylinder head gasket.
Old Oct 28, 2015 | 07:20 PM
Thermo's Avatar
Veteran: Navy
corroded radiator or a bad water pump/thermostat with a failed pressure relief valve. If you are not seeing the temp gauge spike high, then it will almost be garanteed to be a bad radiator.
Old Nov 1, 2015 | 08:51 AM
Larry-Cleveland's Avatar
Test you pressure cap to make sure it is working by releasing pressure. But it will only need to work if the car is overheating. Is it?
Now if the pressure builds up real fast, like 30 sec, it is the head gasket. You can use a tail pip sniffer by the cap, with it off, to see if it detects any exhaust fumes. It should not.
Old Nov 4, 2015 | 03:31 PM
innzane's Avatar
Water caused mine to go super pressure, correct coolant fixed it.
Old Nov 4, 2015 | 11:34 PM
dwclapp's Avatar
innzane's comment may sound odd to some, but it's accurate. We use antifreeze because it boils at a high temperature than water. Why does it boil at a higher temperature? Because antifreeze has lower vapor pressure than water. And lower vapor pressure means less pressure inside our car's coolant system & radiator.
aquifer
May 27, 2022 05:46 AM
FLStype
Nov 3, 2015 05:46 PM
Bryan Fisher
Oct 27, 2015 11:26 PM
Charlroi19
Oct 27, 2015 12:11 PM
deelli
Oct 22, 2015 11:19 PM
