p 1000 Jaguar X type code
Old Jun 6, 2018 | 11:27 AM
megsss3's Avatar
Default p 1000 Jaguar X type code
Hi there,
A p1000 code has been read after two lights start flashing on my screen and Pecus Error E show on the display. The error came when the temperature outside was -15. I have been in to few services in Bulgaria, but no one can idicate the reson for the problem, or clean the computer.
I will much appreciate if you can give any advice or information
Old Jun 6, 2018 | 12:30 PM
avern1's Avatar
P1000 would indicate the codes have been cleared and all monitors have not yet set. If you did not clear them with a code reader then most likely you have a bad battery. That would account for the pecus error and the code P1000. I would get the battery tested and make sure the terminals are cleaned and polished both at the battery and the connections at the other end of the cables.
After sufficient drive cycles the P1000 will set to P1111 which is all monitors are tested and satisfactory.
Old Jun 10, 2018 | 07:02 AM
Dr dome's Avatar
HEY VERN...
I'm up to 7 x types now
haha
Old Jun 10, 2018 | 10:06 AM
Originally Posted by megsss3
..... I have been in to few services in Bulgaria, but no one can idicate the reson for the problem, or clean the computer.
Welcome to the forum megsss3,
As Vern says in post #2, P1000 is a STATUS and not an ERROR.
1. If P1000 is stored in memory, the on-board diagnostic tests have not been completed.
2. If P1111 is stored in memory, all on-board diagnostic tests have been completed.
You will ALWAYS see either P1000 or P1111.
Old Jun 10, 2018 | 03:01 PM
Dell Gailey's Avatar
@ Dr. Dome = what's the old adage about herding cats?
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
JimC64
F-Pace (X761) / C-X17
Oct 27, 2016 04:16 PM
22
Dec 3, 2014 06:09 PM
Jul 23, 2007 09:03 AM
