P0171 & p0172
Old Jan 5, 2012 | 12:31 PM
kalacho2006's Avatar
Question P0171 & p0172(solved on part)
Please need help with this codes,recently my car have this codes and i read all about them. replace the olds o-rings with a leak (I put new greens),new air filter,fuel filter, not leak on the breath hose,clean the MAF and nothing some ideas ?? i hear something of the egr valve but not sure location.
2002 jaguar x type 2.5
ooohhh and my rear left look a positive camber,I check the whole thing with some bushing wear.need replace lower arm? some ideas.
Old Jan 6, 2012 | 09:34 AM
skippy99's Avatar
Had somthing simular problem. check the vacume line fron the master break cylinder to the intake manifold they can crack on the under side . The round valve in the middle of this line [ cant remember the correct name ] can also crack on the underside check it also . when you put the new green o rings in the IMT control valves check to see there seated and not still leaking.
Old Jan 7, 2012 | 12:35 AM
Default Solved
I solved the problem, I only reset the codes and run like 15 highway miles and my light never come back,now I have new Texas sticker. Now my problem is a positive camber on my rear left wheel, it have positive camber wear I know some bushings are worn but I don't know if need replace all the wear pieces or something.
Skippy99 thanks for the tip.
Old Jan 7, 2012 | 03:57 AM
Cadillac's Avatar
Thanks for the update , good to see it was fixed
Old Jan 7, 2012 | 01:42 PM
skippy99's Avatar
sounds like you have a simular problem as me with the rear suspension worn inner edge of rear tires . My was caused by worn lower control arm looks like a wish bone and there is one on each side of the car.Part Number is C2S50863 it is a lateral control arm they seize up or the bushings ware out up here in canada they seize from rust ansd salt . you will need a rear wheel alinement after you replace any parts . Good luck
clubairth1
30
Sep 3, 2025 04:38 PM
caveforce
38
Nov 16, 2015 10:19 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
Bob Gelston
Sep 14, 2015 11:08 PM
androulakis
Mar 30, 2011 07:58 AM
