Parking brake cable lube
Old Nov 3, 2011 | 06:11 PM
gragner66's Avatar
Default Parking brake cable lube
My parking brake on passenger side stays stuck if you engage parking brake. I have used wd-40 but it's still sticking . Anything better out there to lube it with. Thanks for any info
Old Nov 4, 2011 | 07:39 AM
Thermo's Avatar
Veteran: Navy
gragner, I have had this problem numerous times. Unfortunately, I always seem to end up putting a new caliper on to fix the issue. My problems have been internal to the caliper, not the cable itself. You can get a new caliper through Napa for around $110 before tax and core charge. Swapping out the caliper is easy. Just remember to get a pint of brake fluid to allow you to bleed the brake before driving.
Old Nov 4, 2011 | 09:24 AM
Mikey's Avatar
WD40 is NOT a lubricating oil!
Old Nov 4, 2011 | 09:35 AM
billbjork's Avatar
WD40 is good stuff but just remember it's only fuel oil/ diesel fuel under pressure (co2) that smells good. good parts cleaner but lubricating not so much.
Old Nov 4, 2011 | 01:31 PM
disguay's Avatar
Look on ebay for a new caliper! Did this swap yesterday and the scrapyard caliper cost me $36 shipped
Old Nov 4, 2011 | 04:10 PM
gragner66's Avatar
The caliper is new. As of less than a year ago with less than 5000 miles on it But the parking brake assembly is rusted worse than the other side I replaced both rears when I put new rotors on. Thnx for the info looks like I might need a new one though
Old Nov 5, 2011 | 11:57 AM
disguay's Avatar
The rear calipers on these cars are known to have problems. My recommendation is to buy one from a scrap yard and then buy a rebuild kit depending on how loose your new, used caliper
Old Nov 13, 2011 | 11:28 AM
Rip Reed's Avatar
1997 - 1998 Jaguar XK8
Part Number:
48-01980 AD
Part: Oxygen Sensor - Oxygen Sensor
Old Nov 14, 2011 | 03:15 PM
billbjork's Avatar
Default this might help
I found that a very good product to loosen anything is KROIL. Type it into
google and see. I have removed rusted brake connections, hubs, and even cleaned out the jets on a riding lawn mower carb, don't need much and it smells funky but it works
Old Nov 14, 2011 | 11:20 PM
gragner66's Avatar
thnx bill ill look for it in a store
99xk8guy
May 28, 2024 09:36 PM
Rlover
Mar 30, 2016 10:04 PM
neruda
Oct 18, 2015 01:19 PM
sawduster
Sep 11, 2015 10:02 PM
