PCV replaced. Who knew?
Old Aug 8, 2015 | 08:02 PM
04Sport's Avatar
Default PCV replaced. Who knew?
Just replaced my PCV a few days ago along with the smooth breather hose to the ribbed version. The car has more power then I it has had in awhile. I never would have guessed how a gummed up pcv could actually rob performance but it was. Anyone who has not done so I highly recommend the quick change out. I am looking forward to seeing if the fuel economy increases as well.
Old Aug 9, 2015 | 04:31 AM
Mr rx-7 tt's Avatar
Pics of the hose? How did you know it was bad?
Old Aug 9, 2015 | 07:52 AM
Thermo's Avatar
Veteran: Navy
Mr rx, first off, if you have a smooth PCV hose, it is a ticking time bomb. You will know that it is failed by disconnecting the one end and looking at the underside of the hose. Normally in the spot where it goes over a support bracket, the hose will develop a split in it running the length of the hose. When this is going, you will start getting vacuum leak codes (P0171 or P0174) and in extreme situations, you will be put into safe mode where you cannot rev the engine up beyond 3,000 RPM.
Old Aug 9, 2015 | 03:19 PM
04Sport's Avatar
Added a few shots of what I found. Very glad I did the replacements. The Jag OEM parts were cheap and it took maybe 15 minutes from start to finish
60k miles on this PCV
This is what I saw when I took of the original smooth breather hose
Luckily very clean in there
Marka
22
Sep 11, 2016 12:09 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
jonahjob
Oct 1, 2015 07:54 AM
Woznaldo
Sep 26, 2015 11:02 AM
