Peak Back-up camera system
Old Sep 29, 2014 | 10:46 PM
jlpatton's Avatar
Default Peak Back-up camera system
Hello all, 2003 X-Type here and looking to install a Peak back-up camera system I purchased for a really good price. I use to own a 2001 S-type with the back up sensor and really miss that system. The install is fairly simple per the instruction but my problem is that you must tap into the reverse light either the left or right side but I don't know which are the reverse light wires. I have read a lot of post here and looks as if the GREEN/BLACK - GREEN/RED are the reverse light. Does anyone knows!!!
Old Sep 30, 2014 | 08:18 AM
Lcgi's Avatar
Arrow
Hi there,
Why not pull one of the reverse light globes to then see exactly which wire colours are used on the globe socket?
Old Sep 30, 2014 | 11:12 AM
wa3ra's Avatar
G-R is hot, simply use a y-tap to splice into the wire.
Pull the housing, look at the reverse lamp socket; center wire is the hot one!
Old Sep 30, 2014 | 10:56 PM
jlpatton's Avatar
Just so we are clear I removed the left rear lights and found that they all are connected via a single connector! There are no wires which lead to the various lights in the cluster. Can someone confirm 100% that the Green/Red - Green/black are for the reverse lights?
Old Sep 30, 2014 | 10:59 PM
jlpatton's Avatar
Old Oct 1, 2014 | 02:49 AM
SteveSheldon's Avatar
The centre pin on the reverse bulb will be connected to a silver track back to the connector - then check which pin that is on the connector and in theory you'll have the correct wire
Old Oct 1, 2014 | 11:30 AM
jlpatton's Avatar
Default Sucessfully installed back-up camera! Thanks to all
I got her installed! I followed the wiring instructions advice from wa3ra!!!! Thank you so much! I have included pictures! Only problem now is
//Where to mount the monitor unit! I have it hanging out my ash tray right now but will look for a better home in a couple of days!
Attached Thumbnails Peak Back-up camera system-001.jpg   Peak Back-up camera system-002.jpg
Old Oct 1, 2014 | 05:15 PM
wa3ra's Avatar
Happy to help!
That green-black is actually available under the hood as well; it runs from the reverse switch on the transmission all the way back to the (US) driver's side reverse light, then across to the pass side.
I also realized that it runs to the harness for the reverse sensors, so the signal could have been stolen from that connector as well.
DpezXK8
Aug 27, 2025 08:55 AM
mrplow58
Sep 15, 2015 09:58 PM
Ipc838
Sep 13, 2015 03:27 PM
ahunt4
Sep 10, 2015 02:53 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
