Problem with Plastic Cowl
Old Feb 25, 2008 | 10:49 PM
Oldengineer's Avatar
Default Problem with Plastic Cowl
The big plastic cowling that covers the cabin air filter is not staying down tight against the bottom of the windshield like it should. Is there some trick to getting this thing to stay in place??
Regards:
Oldengineer
Old Feb 26, 2008 | 05:07 AM
FactoryJaguarTech's Avatar
Default RE: Problem with Plastic Cowl
just pop it down with heel of your hand. Make sure lined up properly and careful not to crack bottom of glass.
Old Feb 26, 2008 | 09:35 PM
Thanks - I'll have another go at it when the weather warms back up. I've tried a couple of times to pop it back, but, a day later its loose again.
REgards:
Oldengineer
Old Feb 27, 2008 | 02:48 AM
ruslan35's Avatar
I had (have) the same problem. Minecomes loose because of a lip that slips under the windshed and holds it tight is broken off places. Check you lip, you might of riped it off if you tryed to take it off before.
Old Feb 27, 2008 | 10:33 PM
Thanks - I did pop it up to see if anything was amiss on the last warm day we had. I'll take another look at it.
Regards:
Oldengineer
clubairth1
30
Sep 3, 2025 04:38 PM
GordoCatCar
Jan 2, 2017 01:10 PM
jdzubas
Oct 4, 2015 09:14 AM
jehart49
Sep 12, 2015 05:36 PM
sadepol01
Sep 11, 2015 05:26 AM
