Question about water system Xtype v6 3.0
Old Sep 26, 2012 | 11:18 AM
mountie's Avatar
Default Question about water system Xtype v6 3.0
Hi there just bought car and noticed today the water pipes are firm but can sqeeze em....The water is ok oil is ok.but header tank does smell a bit gassey???heaters work fine no over heating at all car runs mint.My mate use to work for Jag and says the hoses do get firm it is normal but how do you explain the smell???? does not use water either? any suggestions?
Old Sep 26, 2012 | 02:42 PM
disguay's Avatar
Could it be coming from your PCV valve?
Old Sep 26, 2012 | 07:44 PM
mountie's Avatar
will that cause the smell???? so do I just replace it or clean it....
Old Sep 26, 2012 | 07:55 PM
Thermo's Avatar
Veteran: Navy
PCV valve is cheap, just replace the PCV valve.
Old Sep 26, 2012 | 08:01 PM
mountie's Avatar
can i get one from ford or do i get it from a local parts place???? in the UK
Old Sep 26, 2012 | 08:28 PM
disguay's Avatar
probably going to need to get it online. Check ebay
Newark Nj Gang
Oct 2, 2015 02:39 PM
javenlevi
Sep 22, 2015 03:37 PM
scatcat
Sep 15, 2015 06:55 AM
Jagfastic
Sep 14, 2015 07:41 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
