rear brakes sticking
Old Sep 22, 2018 | 02:30 AM
fourbyfourbyfar's Avatar
Default rear brakes sticking
Hi all not been on for a while but having trouble with rear brakes sticking on with the hand brake i fitted new calipers and new cables and it still does it if i remove the cable from the calipers and work the lever it moves freely back and forth and returns fully back no problem but when i refit cables they will not return fully back without a little help have looked at the handbrake lever and there is a big coil spring in there it a self adjusting system on a 3.0 auto 2001 this spring seems to be pulling on the cable too much is there any way to adjust this as in the book to replace the lever is a bit of a job
Old Sep 22, 2018 | 05:17 AM
iownme's Avatar
its a jaguar...what do u expect.
do as the previous owner of mine did,
cut the cables at both calipers and call it a day
Old Sep 22, 2018 | 07:11 AM
Thermo's Avatar
Veteran: Navy
Fourbyfourbyfour, if you get under the car, crawl under the center of the car and find where the e-brake lever comes out. Now, follow the cable back to where it splits into 2 cables. If you look between those cables, you should see a nut there. Loosen on that nut some until the e-brakes stop being engaged while the lever is fully down. Sounds like someone tried to fix worn pads by adjusting the nut vice simply running the e-brake lever up and down a few times to allow the brakes to adjust themselves.
If you need to know any more, let us know. The only other "problem" that I can think of is someone found some cables that were close in length and installed those and that is causing the levers to be pulled all the time.
Old Sep 22, 2018 | 09:45 AM
iownme's Avatar
thermo.
he installed new cable
Old Sep 22, 2018 | 10:53 AM
clubairth1's Avatar
Community Influencer
Did you install the parking brake cables? You would need to back off and re tighten the adjuster to get them on.
How did you know when to stop tightening the adjuster?
Maybe you just need to play with the adjustment under the car as Thermo explained?
Old Sep 24, 2018 | 01:25 PM
I've been underneath Thermo and there is no adjuster nut there these are self adjusting I've pulled the lever up and down to let them adjust but not working the brakes stick on and with a little help they will release
Old Sep 24, 2018 | 02:51 PM
Dell Gailey's Avatar
Full video of replacement of cables describing your exact problem. Heed @1:45, watch entire video though =
Old Sep 24, 2018 | 03:43 PM
Thermo's Avatar
Veteran: Navy
Dell, I think you linked the wrong thing. What you linked is a cable tester. not a video on how to do brake work.
Old Sep 24, 2018 | 03:52 PM
Fixed, thx
Old Sep 29, 2018 | 08:44 AM
Hi Dell yes had the same problem last MOT so I changed the rear cables and it passed the retest but not long after they started sticking again so I just stopped using the hand brake as it's an auto it was not a problem but now the MOT is due again I need to sort it
Old Sep 29, 2018 | 09:04 AM
Tried to post some pictures of the handbrake lever but can't seem to get them to upload properly
ja34
Aug 25, 2021 02:05 PM
mikchek
May 8, 2019 11:38 AM
sleddy123
Jun 21, 2015 07:18 PM
mdizzal
Dec 6, 2014 02:16 PM
