Rear decals are glued only, or fastened with pins/...?
Old Jul 6, 2019 | 10:53 AM
kingnero's Avatar
Default Rear decals are glued only, or fastened with pins/...?
See the things circled in green, I want to remove them if they are just glued on.
Can somebody confirm this? As I've had another car where there were small plastic locator pins with barbs, leaving me with holes in the boot... If that's the case, I'll leave 'em alone.
Any suggestions on how to remove them the easiest?
Old Jul 6, 2019 | 11:11 AM
sov211's Avatar
These badges (not decals...decals are plastic sheet transfers) are attached with two-sided tape so there are no holes. If you heat the surface you can remove the badges quite easily.
Old Jul 6, 2019 | 12:10 PM
Dell Gailey's Avatar
And slowly use a length of dental floss looped to "cut" through helps.
Old Jul 6, 2019 | 01:15 PM
kingnero's Avatar
Thx!
TheWarlock
Nov 6, 2015 10:44 AM
jvitez
Feb 28, 2014 12:32 PM
Thermo
Nov 20, 2009 12:14 PM
johnsjag
Nov 3, 2009 07:33 AM
jamlaw125
Sep 12, 2009 01:38 PM
