Rear pads and that dot/nub
Old Jul 2, 2022 | 10:20 PM
ugotmale's Avatar
Default Rear pads and that dot/nub
What is the reason for the dot on the rear pads? There is one on all 4 pads. Should there be and doesn’t it restrict the piston from spinning out as the pads wear down?
Old Jul 3, 2022 | 07:57 AM
Norcat's Avatar
The piston doesn’t spin out, the dot holds it in one position so that the threaded rod inside pushes the piston when its rotated by the ratchet in the handbrake mechanism.
Old Jul 3, 2022 | 09:34 AM
Thermo's Avatar
Veteran: Navy
So, with what is said, you should have aligned the dot with the recess on the piston (as I recall from many years ago).. The piston needs to be prevented from rotating.for the rear of the car.
Old Jul 3, 2022 | 01:01 PM
ugotmale's Avatar
Thanks guys! I aligned it with the piston. Just was a little confused about that dot! Good to know.
edadoune
Dec 18, 2019 07:18 AM
TreVoRTasmin
Aug 6, 2017 06:22 PM
Sonspit
Jul 11, 2014 08:52 AM
TrexM3
Feb 19, 2014 11:50 PM
