relat testing
Old May 1, 2017 | 06:50 PM
Thang Nguyen's Avatar
Default relat testing
How to test the relays?
Old May 1, 2017 | 07:16 PM
avern1's Avatar
The relays have a 12 volt coil that when energized closes the contacts on the relay. First check the side of the relay for the diagram outlining the relay function. The using a multi-meter locate the 2 spades that are for the coil. They will show some continuity. The other 2 spades will show open circuit. Apply 12 volts to the coil side then check continuity on the contact side. If the relay is functioning the relay side will show continuity of a complete circuit.
Digital Will
Feb 21, 2026 05:58 PM
Xx_Xtype_xX
Nov 9, 2016 10:02 PM
hakunti
Oct 22, 2016 08:09 AM
King Charles
Oct 15, 2016 07:45 AM
