Remote stops working
Old Feb 29, 2008 | 07:22 AM
mr.xtype's Avatar
Default Remote stops working
This is happened to me twice so far. When I turn my ignition off and open my door I hear a "chime" now this chime does not come on whenever I opened my door in the past and when it does come on, I shut my door and try to lock it with the remote and the remote does not work. So I have to lock it with my key but then when I return to my car I open it up with they key, do my driving and when I get out again to lock the vehicle the remote starts working again. I am thinking I have some kind of feature which I am not familiar with. Has anyone elseever experienced this?
Its an 02 x 2.5 manual tranny and it has automatic headlights and the knob is always on the off position. If this helps
Old Feb 29, 2008 | 08:12 AM
Dennis's Avatar
ud
Default RE: Remote stops working
Squirt a little electronic cleaner w/lube into your key hole of the ignition switch...then work the key in and out a couple of times.
Old Feb 29, 2008 | 08:17 AM
mr.xtype's Avatar
Thanks Dennis but I will try this, but everytime I open my drivers door after driving and turning off the ignition, should I be hearing the chime? and how can lubing the ignition key hole affect my remote not working?
Old Feb 29, 2008 | 12:41 PM
mr.xtype's Avatar
What is electronic cleaner?Will white grease or wd-40 work? I honestly have no clue.
Old Feb 29, 2008 | 01:18 PM
Dennis's Avatar
ud
ORIGINAL: mr.xtype
Please no!!!![sm=insomnia.gif]
Go to Radio Shack and ask for Spray Electronic contact cleaner with lubricant..It should come with a little spray tube that fits into the spray button...
Old Feb 29, 2008 | 01:34 PM
Cadillac's Avatar
Well, actually I thought WD40 would work [8D]
It's so advertised that let's say your grandma's old televison can be converted into a SONY LCD when you sprayit [8D]lol
Old Feb 29, 2008 | 02:39 PM
Dennis's Avatar
ud
Don't make me slap you Caddy[sm=chairshot.gif]
Old Feb 29, 2008 | 04:07 PM
mr.xtype's Avatar
Caddy who is that chick in your pic? Shes pretty hot!
Old Feb 29, 2008 | 04:25 PM
Cadillac's Avatar
She is Bond ....Charlize Bond lol [sm=bling.gif]
Charlize Theron
Old Feb 29, 2008 | 04:47 PM
mr.xtype's Avatar
bojangles I honestly had no clue my issue was due to the ignition sensing that the key was still present in the ignition. I assumed I had a bigger issue such as the car thinking my headlights were still on. Also I can honestly say I have never used wd-40 for anything else other than loosening a rusted bolt and I have never had to oil or lube anything in my life other than a woman... well thats not entirely true. Its not like I am some rich snob that pays for everything. I am quite handy around the house. I can do repairs and build stuff as well as change light bulbs. When it comes to cars I leave it to a professional as I believe if you dont knwo what you are doing then dont tamper with things because only bad things can happen. Like the above example if I didnt ask if I could use wd-40 then I may have messed somethign up. i guess its easier said... If you dont know what you are doing then ask for help or take it to a professional.
Old Feb 29, 2008 | 08:49 PM
Dennis's Avatar
ud
ORIGINAL: cadillac
Charlize Theron
Ah-Ha!..I knew she looked familar...Wish you would have mentioned it sooner..I've been racking my brain trying to figure out where I've seen your picture of her before...[sm=headbang.gif]
Voted the Sexiest woman...I concur[8D]
Old Mar 1, 2008 | 03:25 AM
Cadillac's Avatar
Hey Dennis, why didn't you pm me ? [8D]
tberg
Sep 7, 2015 07:32 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
arnoldmilk
Sep 3, 2015 07:42 PM
Sep 3, 2015 12:21 PM
XJsc-guy
Sep 2, 2015 11:43 AM
