Removing driver inner door panel; fixing window regulator
Old Apr 11, 2016 | 03:32 PM
wa3ra's Avatar
Default Removing driver inner door panel; fixing window regulator
Well, the regulator itseld seems to be fine, but those little chunks of plastic that hold up the window glass seem to have suicided.
I hunted down the replacement pieces, and it looks like replacing them won't be "too" big a task...
but the thread showing me how to remove the inner panel has lost its images.
Does anybody have a diagram showung me where the screws and clips are handy?
I do have 'real' removal tools for the clips, and a whole bag of replacements, but I'd rather not break any of them in the process if I can avoid it.
Good practice, anyway, since I need to fix the outer door handle on the passenger side, too...
Old Apr 11, 2016 | 10:02 PM
Lemons Racer's Avatar
I have removed the door panels, but they will not be reinstalled. There were just a few screws if I remember correctly. A couple were hidden with pop off plastic covers. I don't have a door panel in front of me, but I think there were two screws on the bottom and then one in the handle area. The rest just popped off. If you want pictures of the panel, inside and out, and can take some on Friday. Also, if you need any parts let me know I still have my panels.
Old Apr 12, 2016 | 04:07 PM
X-TypeMentality's Avatar
Hey Lemans, if this gentleman doesn't need any parts, what color are the door panels you have? And on the drivers door panel, did any of the female clips beak? The part of the door panel injection molding design and not the clips that press into the door...
Old Apr 12, 2016 | 04:27 PM
You can see the color on top of the tires. I can take closer pictures if you would like. Especially of the backside so you can check for broken clips. They should be I'm good shape. I was careful taking them off.
And before they were removed
Old Apr 12, 2016 | 04:29 PM
Aw shucks, I have black interior. Gotta keep it matching. Thank you though! Good luck with the racecar.
Old Apr 12, 2016 | 04:49 PM
Old Apr 12, 2016 | 07:19 PM
hlgeorge's Avatar
Are you going to be removing the wood cover on the passenger side of the dash. Mine is cracked and looking for a replacement. Your interior is the same as mine. Might also be interested in the console armrest cover.
Old Apr 12, 2016 | 07:40 PM
Yes, we do not need any of the interior and other than the seats we still have all of it. We are keeping the wood center stack just for aesthetics. PM me and we'll figure it out.
