Replacing Cooling Fan
Old Aug 4, 2011 | 11:23 AM
teflondon's Avatar
Question Replacing Cooling Fan
Hey Jag family.. how hard is it to replace the cooling fan. i accidently cracked one of the blades and now the fan is off balance bad. so i purchased another fan. So if someone has replaced it. Please let me know if its a DIYS job.
Thanks in advance family
Old Aug 4, 2011 | 03:37 PM
Thermo's Avatar
Veteran: Navy
Don, it isn't that bad. As I recall, you have 2 bolts on the bottom of the fan assembly (bottom corner on each side) and then you need to unplug the wiring to the fan controller. From there, lift straight up. Please keep in mind that odds are you will have to remove the tray under the radiator which will add some time, but will make getting at the lower bolts that much easier. It will require the use of a T-27 Torx bit. May also need to get the front end of the car up in the air a little more so you have room to stick yourself in under the car. It all depends on how big you are.
You should be able to get a fan assembly for dirt cheap as there are tons of them out there missing their temp control modules.
JarodL
Mar 7, 2024 01:39 AM
Jjscruggs1
Aug 2, 2017 04:40 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
