Right side Dipped (low) beam not working
Old Sep 25, 2018 | 05:15 PM
Vitor Oliveira's Avatar
Default Right side Dipped (low) beam not working
Hi guys.
I was just adjusting the headlights in my drive, and all of a sudden, the dipped (low) beam on the drivers side (right side) has just gone! Bulb is fine, still tried with a new one and nothing. Checked both fuses F29/30 and they were fine!
Any suggestions? i am kind of freraking out, because I have the MOT in November and it wil fail if it stays like this...
I really want to find the fault...
Thank you
Old Sep 25, 2018 | 06:39 PM
Dell Gailey's Avatar
Pull the connector off the back of the bulb and check it for power. If the feed has power it's the bulb. If no power (you say fuse is fine) replace it anyway , check there is power flowing through the fuse (multimeter, little metal tabs on fuse top) and recheck power at harness (if yes) plug back into the bulb. If no, it's more than likely wiring.
CarLuva
Jan 11, 2019 11:04 PM
ragman1171
Sep 26, 2014 09:23 PM
hawaiiboyy
Apr 13, 2014 04:44 PM
SteveS55
Nov 6, 2008 09:27 PM
SteveS55
Nov 6, 2008 05:29 PM
