Rims what size
Old Sep 18, 2011 | 10:43 PM
newjag2002's Avatar
Question Rims what size
Hey now i was wondering what size rims will fit my 2002 X-Type OEM i have sean many nice rims off other jags and need to know and were can i get parts for my X need clutch set and wire harness for the front fogs. thank in advance.:con fused:
Old Sep 20, 2011 | 06:09 PM
vc612's Avatar
Default Rim size
Well if I were you I would contact the dealer and ask them as far as the size is concerned. I know for my '03 Jag I have 16" chrome aftermarket rims. The car came with 17" rims on them factory from the dealer. I am sure you car will fit these sizes and maybe larger. Good Luck!
Old Sep 20, 2011 | 07:36 PM
mohrd's Avatar
newjag2002, the X-type has several OEM wheels that fit. 16, 17 and 18`inch. If you are wondering about wheels from other models fitting, S-type wheels will but the offset is slightly different, about 8mm and could be wider than what comes on the X at 8 inches rather than 7 and 7.5 inches.
as far as tyhe clutch and wiring, you can check with our on-site vendors like Nalley.
Failing that, exexpat and Thermo should be along to discuss all things wheel and electrical related. I hope.
Poet
Feb 7, 2025 02:18 PM
bdboyle
Sep 16, 2019 05:58 PM
JAMES1944
Sep 29, 2015 11:58 AM
Marque
Sep 27, 2015 10:28 PM
