Rough idle?
Old Dec 10, 2017 | 07:37 PM
Lawenforcer's Avatar
Default Rough idle?
Hello all, I am having a major issue and driving me crazy. My 02 Xtype has a really rough idle only when it is like 35 degrees or lower, like when you first start up in the mourning. It will run rough for a little bit until it starts warming up and then it won't do it for the rest of the day. I have replaced the breather hose that everyone suggested and the IMT seals. Is there anything at all I can check and or replace. It has no check engine lights on etc...and only does it when it is really cold out...please, please, please help me on this. I need to get it fixed. Thanks
Old Dec 11, 2017 | 02:12 AM
JagV8's Avatar
Look for threads about fuel trims then watch yours.
Old Dec 11, 2017 | 04:56 AM
Mark Murphy's Avatar
Inlet manifold gaskets are past their prime buy some silicone gasket maker, take the inlet off, clean and apply, it is not a hard job.
Old Dec 11, 2017 | 07:25 AM
foxbottom's Avatar
Pay particular attention to the lower manifold gaskets. Sometimes when people replace the plugs, they just do the upper ones. Mine was acting the same way. After replacing and dealing with every possibility of vacuum leaks, I replaced those lower manifold gaskets and problem solved.
mystype04
Apr 11, 2019 08:46 AM
93greenconv
Jul 27, 2014 09:04 AM
xjrwithproblems
Nov 9, 2013 02:56 PM
Ipc838
Jun 26, 2012 02:50 PM
May 24, 2006 02:08 AM
