same ol' HID questions
Old Aug 22, 2013 | 07:41 PM
X-TypeMentality's Avatar
Default same ol' HID questions
a while back I found a good thread where I think it was thermo who listed exactly what to buy but now I cant seem to find it, or a direct answer...1st of all its an 02 2.5 and I'm going with 8000k...is it H1 or H11? I just saw a minute ago on an older thread a dude saying H1 for both. if that's the case, would I order 2 of the exact same kits? Or, buy one of the ones I see that states fog light? This is probably pretty repetitive by now but any help would be stellar! thanks.
Old Aug 22, 2013 | 08:07 PM
Dr dome's Avatar
They are H1. You do not need the "fog light" kind. You can get 2 of the sets and they will be just fine. If you need the ebay item # this is it 261267353325.
Good luck,
The Dr!
Old Aug 23, 2013 | 07:27 AM
Thermo's Avatar
Veteran: Navy
The headlights are H1 bulbs. If you can get a kit that is specific to the H1 bulbs, things will be a little bit easier. If you get one of the universal kits (ie, covers, H1, H11, 9007, 9005, etc), then you have to do a little more work. Either way it is not bad. The big thing is making sure you take the time to remove the headlight assembly to do things right. Otherwise, you risk breaking the internal supports and then you have a big mess on your hands. If you have any further questions, let me know. I will tell you all that I know.
Old Aug 23, 2013 | 01:55 PM
emaraszek's Avatar
At one point, Jaguar changed the fog lights to use H11 bulbs instead of H1 bulbs, but as far as I know the headlights are H1 on all model years.
On my 2005 the fog light bulbs are H11, but since you have an '02 I'm sure you have the H1 fog lights. Basically the older models with the H1 fog lights have a plastic "adapter" type of piece that holds the bulb into the housing, while on the later models with the H11s the bulbs have a built-in "adapter" the secures itself to the housing.
I would also recommend you start off with a well-made kit. I got the eBay ones first and not only were they not true to their color, they were flickering from day 1 and failed within a few weeks.
I recommend these ballasts:
MAXLUX Universal Replacement HID Digital Ballast (CANBUS, AMP Connectors) : Amazon.com : Automotive MAXLUX Universal Replacement HID Digital Ballast (CANBUS, AMP Connectors) : Amazon.com : Automotive
I have 4 in my car right now and they've been running strong for about a year now. They never flicker either. They're a bit more expensive, but you get what you pay for
Old Aug 23, 2013 | 08:26 PM
Thermo's Avatar
Veteran: Navy
I will second the Maxlux ignitors. You get them next to the others that you will find out there, it will be obvious as to why everyone recommends them. Even I have started to convert my cars over to these.
Old Aug 25, 2013 | 01:12 PM
Damn I wish I would've known that. I ended up going with these from Amazon...
http://www.amazon.com/gp/aw/d/B00COOSJKI/ref=redir_mdp_mobile?psc=1&redirect=true&ref_=oh_d etails_o02_s00_i00
Hopefully they work out well for me. If not, can I just replace the ballast later down the road? Also, along the same lines, can I just replace the bulb for a different temperature later down the road? Thanks for the help folks.
Old Aug 25, 2013 | 03:52 PM
Thermo's Avatar
Veteran: Navy
Mental, Yes, you can replace the ballasts and bulbs later on down the road. BUT!!!!!!!!! You knew that was coming. There are 2 different style bulbs out there as it relates to the connectors. So, you need to make sure you get the correct style bulb for the ballasts that you have. Along those same lines, you will find that HID bulbs come in 3 different power ratings (35W, 50W, and 80W). You can not mix and match the bulbs and ballasts. They are dramatically different and to mix and match WILL!!!! lead to a failure of something.
So, as you can see, the parts can be interchanged. But, there are limitations.
redrover41
23
Sep 25, 2015 01:33 PM
VRB
Sep 15, 2015 08:18 AM
DustysSon
Sep 13, 2015 04:17 AM
afterburner1
General Tech Help
Sep 7, 2015 08:43 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
