Several issues after replacing radiator
Old Sep 1, 2017 | 12:03 AM
nahum's Avatar
Default Several issues after replacing radiator
I have a 2003 x-type 2.5 i replace the radiator because it was licking water and it worked fine for a day but then some troubles started happening, the first one is it jerked and all of the sudden im having issiues with gear shifting , it feels like first gear its not workin or sliping, the other issue is the headlights dont work, fuse 67 keeps blowing up, i scanned it and it shows several codes which are p0102 P0112 P0430 and p1643, any help will be highly appreciated
Old Sep 1, 2017 | 03:49 PM
new mexico's Avatar
See if you disconnected a plug or so, and all the wires you might have touched
by replacing the radiator.
Things happen you know.
Walter
