Snorting Throttle Body
Old Jun 23, 2018 | 12:35 PM
Vaucel's Avatar
Default Snorting Throttle Body
Hey guys! So my 03 Jaguar has lean codes both on bank 1 and 2 and right now, the only noticeable thing I can observe is the throttle body sounding like it’s snorting or like ticking kind of. My average mpg is really low at 12mpg and it’s been constant like that for the 2 weeks i’ve had my X-Type. Along with that is it has a rough idle. Any ideas? Really appreciate all the help!
Old Jun 23, 2018 | 05:31 PM
avern1's Avatar
Lean codes for both banks is an indication of un-metered air AKA vacuum leak. You need to check the inlet hose from the air cleaner, the gasket for throttle body to manifold and last but not least the PCV hose from the cam cover to the manifold. You have a crack or brake on one of them. The other areas known for vacuum leaks are the brake booster vacuum line attached the back of the manifold and the IMT seals on the right hand side of the manifold.
Old Jun 24, 2018 | 03:32 PM
Dell Gailey's Avatar
And check your air filter
Stounedi
21
Dec 23, 2017 06:33 AM
bullittandy
Sep 8, 2016 02:31 PM
juha_teuvonnen
Dec 17, 2014 09:35 PM
sws805
Jan 24, 2013 10:58 AM
rvaha
Feb 4, 2012 05:00 PM
