So, who has the most miles?
Old Aug 1, 2013 | 09:14 AM
Sinner650r's Avatar
2001 S-Type 3.0 with 182,215 on the dash. Still strong running for my 2 hour per day commute. Looks great too, no rust! Pics will be up shortly.
Edit: sorry, just noticed this is an x-type thread. Darn mobile....
Old Aug 1, 2013 | 11:00 AM
Spikepaga's Avatar
Originally Posted by Redthing
I'm right at 155,000, original tranny, transfer case, and engine here too...the only thing I've done is preventative maintenance such as the starter, fuel pump, spark plugs, etc. I did have to replace the coolant tank, and a vaccum line, but other than that no big issues. I do need to change the shocks...I'm assuming they are from the factory since I bought the car @ 40k and haven't changed them!
It has even survived an attack from a rather large tree several years back:
https://i.imgur.com/00pYsm0.jpg
https://i.imgur.com/x2zTSYx.jpg
All it took was a bit of rubbing compound...and the factory paint still looks great today. These cars are built to last with proper maintenance!
On your tree photo the leaper looks like she's running away into a ditch like in the new cars !
Old Oct 20, 2013 | 10:46 AM
TexJag's Avatar
Originally Posted by Justink201
I was thinking about how my car has 173k on it, but is in great shape and runs wonderfully...it got me thinking, I wonder what kind of miles other x type owners have on theirs. Could be fun...I'll start...
2004 2.5 5 speed with 173k miles.
2002 3.0 194k miles
Old Oct 20, 2013 | 12:12 PM
billbjork's Avatar
Default 03 X type 2.5
160K, Original drive line. Flushed transfer @ 140K, replaced water pump @ 80K, all "O rings" booster pipe, plugs,thermostat and water pipes @ 130K. Needs bank 1 O2 sensor. Regular oil/filter with mobile - one . only use Bosch filters , 87 octane gas, Dexcool antifreeze,NO additives in oil or fuel(we have 10% ethenal)
Old Oct 20, 2013 | 04:20 PM
bahnjee's Avatar
How about the fewest miles? :-)
My 2003 X-type has only 89k.
Not bad for a ten year old car. Yes, I drive it every day. I live about 5 miles from my work and have no life , so I don't put a lot of miles on it.
Old Oct 20, 2013 | 05:49 PM
Aonsaithya's Avatar
Mine had 39k miles 1.5 years ago, now 50k. If I remember correctly, there's been one 2004 for sale here that has done under 13k miles.
Old Oct 20, 2013 | 06:48 PM
DPK's Avatar
DPK
Pamela Lee Anderson....oops, sorry you're talking about cars...my bad
Old Oct 20, 2013 | 07:12 PM
  #28
DPK's Avatar
DPK
I traded mine (03 X-type 3.0L) back in Aug of 2011, and it had 82,000 miles..Without any major issues.
Things I did to keep it running good over the years (in no particular order):
  • Replaced all the Battery cables
  • Replaced Battery once
  • Replaced Water-pump
  • Replace IMP regulator "O" rings
  • Replaced Coolant Reservoir Tank
  • Replaced Fuel Tank Sending unit
  • Replaced Fuel Filter
  • Changed Transfer case lube (twice)
  • Changed Rear Diff lube
  • Greased Prop shaft center support bearing
  • Replaced all the brakes; with EBC Sport Rotors and Akebono Euro Pads
  • Bled Brake fluid every other year with Jag Brake fluid
  • Drained and flushed Coolant every other year with Jag coolant
  • Drained and refilled P/S fluid every 12,000 miles
  • Changed oil and filter every 6000 miles with Castrol Edge or Syntec
  • BG Transmission service (drain, conditioned, refilled) every 30,000 miles
  • Replaced Intake filter every 12,000 miles
  • Replace Pollen/cabin filter every 12,000 miles
  • Dash Defrost vents replaced (the Rattling SOBs) Siliconed them
  • Driver side sun-visor replaced
  • Had the 4 wheel alignment done every year
  • Replaced tires once at 40,000 miles
All in all nothing major...Never left me stranded other than when the battery failed and that was in my garage.
Old Jan 13, 2014 | 04:12 PM
mju77's Avatar
01 x type 2.5 v6 manual currently on 163k. original everything. well serviced with new 02 sensors, new filters and plugs. drives almost as good as new...
Old Jan 13, 2014 | 04:22 PM
  #30
Five Speed's Avatar
2002 2.5 manual ....only 55.000 in 12 yrs ...
Old Jan 13, 2014 | 04:29 PM
  #31
rclangelan's Avatar
I bought my 2003 in 2013 with only 22k miles on it. Pristine.
One year later I'm just shy of 35k.
Barring accidents, I can see myself keeping it for a long time.
Old Jan 13, 2014 | 04:55 PM
  #32
sdettra's Avatar
2006 with 102,000.
Put away for the winter and cant wait till spring.
Old Jan 13, 2014 | 05:01 PM
  #33
Coralkong's Avatar
2003 X Type 3.0
Daily driver. Northern NH, USA....104K and going strong!
Old Jan 13, 2014 | 10:01 PM
  #34
AlfaVeloce's Avatar
Some impressive miles on here. Good Job.
We're at 134K. 2002 X type 2.5. But, it is on its second engine...
Old Jan 13, 2014 | 10:18 PM
  #35
bracester's Avatar
2003 2.5 with 104k, running so strong its stupid...
Old Jan 14, 2014 | 12:14 AM
  #36
bdevenyvm's Avatar
2004 X-Type has 185000 and change. But it's limpin'.
Old Jan 14, 2014 | 05:16 AM
  #37
Lavaman's Avatar
Original errrything
Old Jan 15, 2014 | 05:35 PM
  #38
fay66's Avatar
The 2003 2.0D I'm looking at has 130K and is on a used car lot, I don't think there's much history with it as it was supposed to have been owned by a mechanic who did everything himself, I'm a little wary as I've done my own work on many of cars I've owned over the last 50+ years, but I always used to keep a record of everything, perhaps that's just me.
It's also nice to read that someone else has bought from a used car lot he one I'm considering but seems to have been well looked after, but another one the same I looked at today was quite rough and certainly not worth looking at further.
Old Jan 15, 2014 | 09:33 PM
  #39
jgbfms's Avatar
2004 3.0. 145,000
I bought her last spring with 135,000. I love her to death. I've replaced the TC fluid twice. I installed a ball valve on mine and it's very easy to change. I also replaced the transmission fluid. I put new plugs in her the first weekend I had her. They were original. I owned a '01 S Type prior to this and I enjoy the X more. She handles like a sport car.
Old Jan 22, 2014 | 04:20 PM
  #40
David Souder's Avatar
226k on our '05 2.5L, manual transmission. Everything is stock with the exception of the water pump that was replaced at 218k and now looking to replace the rear wheel bearings. It's been a daily driver for my wife.
