Sound System
Old Aug 20, 2012 | 09:50 AM
Wildcats2012's Avatar
Default Sound System
I am new to this thread so the answer to my question is probably out there somewhere buti thought i would go ahead and ask anyway. I recently pirchassed a 2002 Jaguar X-Type and would like to install a sound system. I already have my system picked out but was wondering if i would need to install an aftermarket head unit or if it could connect to the stock one. Also i saw something about the ACM and didn't know if a system could connect to it. The ACM is pretty high priced and i am on somewhat of a budget so if anyone knows the best and cheapest way to go that would be great, thanks.
Old Aug 20, 2012 | 10:35 AM
jagryan85's Avatar
Hi, sounds to me that you need these to let you connect an amp to your factory head unit
OE RADIO SPEAKERS TO RCA CONVERTER FOR AMPS ON FACTORY RADIOS PC1 | eBay
Ryan
Old Aug 20, 2012 | 02:38 PM
Thanks Ryan, I would also like to be able to connect my MP3 player sorry should have included this in the original question.
Old Aug 20, 2012 | 03:10 PM
Thermo's Avatar
Veteran: Navy
Wildcats, do you have the NAV setup or do you have a stand alone radio? This makes a big difference as to what your options are. If you have the stand alone radio, then you can do just about whatever you want. if you have the radio with the built in NAV and HVAC controls, then your hands are kinda tied as you would end up having to pretty much redesign your HVAC system since you would no longer have any controls for what you have currently.
As for the ACM module, if you look on E-bay, you can normally find it fairly cheap. Your other option is to find an "FM Modulator". This will take the output of your MP3 player and convert it over to an FM frequency. Then all you do is tune your radio to a specific radio station and you then get to hear your MP3 player through the radio. This hard wires into the antenna, so, the sound quality is going to be about as good as you can get without a direct feed like the ACM provides.
Old Aug 21, 2012 | 08:50 AM
Thermo I have the stand alone radio so hopefuly that makes it much easier. I have been looking for the ACM but can not find it anywhere so if you know anyone on here who sells them that would be great. Thanks for the respnse, I'll look into the FM Modulator.
mbergen
Oct 23, 2019 10:26 PM
Daim
Nov 28, 2016 09:28 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
Mike Green
Sep 7, 2015 12:39 AM
philwarner
Sep 3, 2015 10:14 PM
