Squeaky rear end and tire wear
Old Aug 30, 2016 | 07:57 AM
andybsmith's Avatar
Default Squeaky rear end and tire wear
Used silicon spray to hopefully stop the annoying squeaks but whilst the rear wheels were off I noticed that both tyres are worn on the inside edge. The car has a towbar so obviously used for towing in the past, am I right in thinking that saggy rear springs would cause the rear wheels to camber out at the bottom and in at the top thus placing extra strain on the rest of the components. The ride height is about right at 365mm each side (the haynes book of lies give it as 370 +/- 15mm). I gather that because mine has chrome trim not colour matched trim it is not the sport model.
Old Aug 30, 2016 | 08:07 AM
Revere's Avatar
Wearing on the inside is a sign that the rear lower control arm bushes are worn. They are also called baby arms (because they look like baby arms). You buy the arms with the bushes already in them. If you search there are lots of posts about replacing them. Less than an hour's work.
Old Aug 30, 2016 | 08:17 AM
Paulc732's Avatar
take a look at this thread post #5
https://www.jaguarforums.com/forum/x.../tires-165404/
Old Sep 2, 2016 | 03:06 PM
Thang Nguyen's Avatar
Happen to my previous X-Type, replace all the suspension bushes and shock will fix it, need to be realignment too. if you can't do it yourself, it will make a hole in your pocket
Old Sep 2, 2016 | 05:37 PM
avern1's Avatar
The most frequent problem with the tires tilting inward at the top is the upper control arm. Attached is a link to a forum thread for and adjustable, economical replacement option. Noises can be bushings, drag links on sway bar and shock mounts.
https://www.jaguarforums.com/forum/x...rol-arm-88530/
Old Sep 9, 2016 | 10:02 PM
EasilyConfused's Avatar
Definitely the LOWER control arms, but if you are taking the wheels off and replacing them, go ahead and check all of the bushings under the rear. I replaced my uppers when I replaced my lowers. Bushings looked decent but I replaced them anyways since I had the car up in the air. Get a torch. It comes in handy when taking the bolts out. They are in there pretty tight with all of the build up (dirt, rust, etc.)
jagtoes
Apr 8, 2016 06:14 PM
Oct 15, 2007 06:29 PM
bojangles
Feb 17, 2007 02:54 PM
Exterior
Nov 12, 2006 09:34 PM
andersen06
Sep 18, 2006 12:18 AM
