Starting Delay
Old Nov 3, 2021 | 02:53 AM
Osura Romitha Haturusinghe's Avatar
Default Starting Delay
X-type 2.0L Automatic 2003 has indicate the check engine light and we find the fault in cam sensor (Cam position sensor range/performance fault [P0346]). I replace the cam sensor. But the problem is not solved. Then we check the engine wire harness and its OK.
Old Nov 3, 2021 | 03:28 AM
h2o2steam's Avatar
Hi,
Please clarify your engine type..........2.0L Diesel or 2.1L petrol V6?
Old Nov 3, 2021 | 06:44 AM
Originally Posted by h2o2steam
Hi,
2L petrol engine
Old Nov 3, 2021 | 05:10 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...e-help-217779/
https://www.jaguarforums.com/forum/x...sensors-52541/
The SEARCH function in this forum is a marvelous tool.
Old Nov 3, 2021 | 05:42 PM
h2o2steam's Avatar
Hi,
So walk us through what is actually happening there for you....
You have an amber check engine light displayed.....but if you turn the key to start the car, does the engine turn over normally (crank) and if so, does it start?
Have you pulled the ECM fuses for 30 minutes to try to clear any temporary errors from the ECM?
I think with the 2002 production model you have you are looking to pull F32 and F37.
That might clear any ECM lock out you might be experiencing, so you can resume testing for other issues and codes.
jeff8259
Nov 15, 2017 05:55 AM
agirouard
Nov 20, 2013 05:21 AM
agirouard
Nov 19, 2013 04:57 PM
03Jag4.2Stype
US Western
Apr 4, 2012 08:05 AM
SirJag
Apr 3, 2011 08:44 AM
