Starting issue X Type 2Ltr 2004
Old May 24, 2013 | 09:22 PM
Jeffre's Avatar
Default Starting issue X Type 2Ltr 2004
Hi
Could I have some help with a starting issue. I have had the famous X Type battery light problem for a while and will change the earth cable. The car has had intermittent starting issues and when I connected a battery pack the car would start. I charged the battery reconnected and then all I got was a clunk noise when I tried to start the car. I connected a error code reader and got a transmission error code. I moved the gear change leaver around and after a few attempts the car started. I tried a restart and after 4 tries more clunking the car started again, I cleared error codes and took car for a spin and went through the same restarting process same results and error code came back.
Could it be the earthing issue or a starter motor on its way out?
Jeffre
Old Jun 7, 2013 | 11:02 PM
Jeeves12's Avatar
Jeffre - Have the amperage checked out on the battery. You could have a bad battery cell. The battery will show 12v, but the amps will be too low to turn the starter.
stanjag
Dec 29, 2024 08:26 PM
Drew2006
Nov 24, 2015 11:14 AM
johanasu
Sep 3, 2015 12:39 PM
1964Daimler
Sep 2, 2015 11:41 PM
NinoGrimace
Aug 26, 2015 05:15 AM
