Starting issues - ‘04 X-Type
Old Nov 18, 2019 | 06:53 PM
MilnerJ's Avatar
Default Starting issues - ‘04 X-Type
Attempted to start my car November 14, 2019 and it didn’t turnover. Jumped it, and it fired right up. Went to start it the next day and the same thing happened so I jumped it again. The third day I had the same issue so instead of jumping it, I pulled the battery and drove my truck with the loose battery in the back to have the battery tested. No issues with the battery besides only being around 30% charged so I let them charge it for a few hours. Picked up the battery, reinstalled it and it fired right up again. Chocked it up to the cold weather, didn’t think anything more about it. The next day I attempted to start it again to no avail. So I jumped it to get it started and pulled the lead off the battery to see if the alternator would keep the engine running and luckily it did. However, now I don’t have a clue what is draining the battery while the car is off. I hear a whirring noise in the dash but from what I can tell from this forum is that the noise comes from an air sampler and is totally normal. Not to mention I wouldn’t think the tiny air sampling motor would kill a battery in less than a day. Has anyone else has this sort of issue?
Old Nov 18, 2019 | 07:37 PM
Dell Gailey's Avatar
Bad battery, a "normal" battery check at like an AutoZone, etc. is not sufficient to properly diagnose a bad (or soon failing) battery.
Post #10 =
https://www.jaguarforums.com/forum/x...er-car-212404/
Old Nov 18, 2019 | 08:02 PM
MilnerJ's Avatar
Post #10 =
The battery is a Duralast Gold purchased/installed in October of 2017. Do batteries installed in Jags go bad that fast typically? The battery in my truck as been installed since July of 2016 without any issues like this.
Old Nov 18, 2019 | 08:27 PM
Any battery can go bad. Length of service has little to do with an inherent fault of the unit. That's why they have warranties.
If you suspect or prove battery is not the problem, you can do a SEARCH here for "parasitic battery drain" thread with procedure to find the cause.
Old Nov 19, 2019 | 11:51 AM
sov211's Avatar
And the small aspirator fan for the climate control does not run constantly; it goes into operation the moment the driver's door latch is moved and remains in operation until the engine has been shut down for a period of 15 minutes or so - which means that it SEEMS to be running permanently.Not so.
Your problem is with the battery. The history you give shows that it has not been brought to full charge.
Old Nov 20, 2019 | 12:10 PM
TonyJ1977's Avatar
Your battery may not be bad but you also cannot fully charge a battery in just a few hours. Have it fully charged by someone that knows what their doing or just replace it. Jags are very temperamental when it comes to battery’s not being fully charged
TheTerrible Keleb
Jan 6, 2019 10:04 PM
Jagstefano
Dec 26, 2018 04:25 AM
muskox3437
19
Oct 13, 2016 09:52 AM
Cadillac
General Tech Help
Sep 23, 2014 12:39 PM
mojorising
Oct 26, 2010 09:52 AM
