Steering Wheel Center Emblem
Old Aug 26, 2014 | 06:20 PM
wa3ra's Avatar
Default Steering Wheel Center Emblem
Can any body tell me what this 45mm badge came off of, and where to find the correct growler in 45mm?
This is my airbag center cap. Again, it is 45mm, not 58mm!
Old Aug 27, 2014 | 05:12 AM
Aonsaithya's Avatar
The edges look like the normal badge, perhaps that's a sticker? No idea why anyone would do that, the original badge looks nicer, unless it has been damaged and that's there to cover it up.
See this thread for some more info on the badges:
https://www.jaguarforums.com/forum/x...l-badge-79927/
Unfortunately, it is pretty much impossible to replace the badge itself. You might be able to put a new stick-on to replace the one you now have, though, if you find one in correct size. I'm only aware of this.
Old Aug 27, 2014 | 12:30 PM
wa3ra's Avatar
That is actually metallic plastic, and it is cloisonné, not a sticker.
The stock airbag centers look to be 58mm, but this thing is only 45mm in diameter.
It is almost as though the airbag is not an original Jag part...although that would not make a lot of sense.
In the long run, I'd like to put a later model wood and leather wheel in, but in the meantime, this thing just looks so cheesy...
Old Aug 30, 2014 | 11:13 AM
ghoward986's Avatar
My badge was damaged. We replaced the steering wheel with a late model one and installed a new air. Total cost less than $300 but this makes a huge improvement to the look of the car. The old airbags have an issue with curling up at the edges.
Old Aug 30, 2014 | 03:09 PM
wa3ra's Avatar
Yep, I have the curling edges.
We are going to put a later wood and leather wheel in, which will solve the problem.
I did find a supplier who makes the leaper badges in 45mm with a carbon fiber or silver background, and also found a UK vendor who makes domes growler stick-ons as well.
They don't advertise them as being for the steering wheels, but a check of the design (and many other car manufacturers) shows that MANY suppliers use adhesive badges, rather than tabbed badges, on their air bags.
The bag cover opens UP, away from the driver, and fast enough that if the badge were to separate from the cover, it would hit the ceiling, not the driver, so the assumed safety issue is actually a non-issue.
Actually, the CF look center is not too bad looking:
Old Aug 30, 2014 | 10:00 PM
JagX02's Avatar
Who makes these badges I do need one for my car
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
Burdedw
Sep 12, 2015 10:39 AM
1964Daimler
Sep 9, 2015 11:28 AM
