Temp gauge in the red - Solved
Old Apr 7, 2023 | 01:06 PM
JagV8's Avatar
Read it via OBD live data and see what it does moment by moment from engine on.
If it's some sort of flexing wire or short the reading will be all over the place jumping around.
Old May 19, 2023 | 04:47 AM
Geoff Collins's Avatar
The wires in the wiring harnesses do not 'flex or jump around'. They are stable.
The P0116 error code did NOT help. If it's a code for the following as suggested above, then it's of no use in my case:
  • Faulty Engine Coolant Temperature (ECT) sensor
  • Engine Coolant Temperature (ECT) sensor harness is open or shorted
  • Engine Coolant Temperature (ECT) sensor circuit poor electrical connection
I stuck to my gut instinct that it was NOT an electrical fault and replaced the thermostat. I have since done over 300 miles and the problem appears to have gone away.
The error codes were of no help.
Old Jan 25, 2024 | 04:37 AM
Originally Posted by baffourg
guys, lately i have noticed that whenever am driving my temperature gauge rises to the red but the car doesnt overheat. i had the thermostat cleaned cos it had carbon deposits around it but it didnt solve the problem either, what could be causing this? any help will be greatly appreciated. thanks
I had a similar problem on my X Type Jag. The temperature would occasionally (about once every couple of weeks, the car is used most days) go into the red within about 30 seconds, you could see the temperature gauge needle actually moving. I replaced the thermostat and that fixed the problem for me.
Old Jan 25, 2024 | 10:48 PM
daddylogan's Avatar
This happened to me as well back in 2021. I changed both the thermostat and the coolant sensor and the problem has never returned.
peace out,
daddylogan
jeremy_watson
Jan 30, 2022 04:23 PM
Johnken
Oct 11, 2021 02:24 PM
INDYJAG-84
Nov 30, 2019 02:05 PM
Dudeman44
16
Aug 6, 2013 08:36 PM
pdog2000
Jan 31, 2011 07:24 PM
