Thermostat climbs to 1/2 Point (Help)
Old Aug 27, 2011 | 03:19 PM
jagone's Avatar
Default Thermostat climbs to 1/2 Point (Help)
I start the car and within 2 mins the thermostat is at the 1/2 way point and stays there cold or hot, no diff. Driving hot does not seem to over heat, my gut says it is a bad stat, or sensor.
This is a 2.5 L 2002 X Type
Any ideas are appreciated
Old Aug 27, 2011 | 03:34 PM
chernobee's Avatar
sounds ok to me. mine acts similar, before and after replacing the water pump, t-stat, t-stat housing and various hoses. took it to a professional for a leak. imho, if its not leaking or overheating dont trip. if you got a couple extra dollars and/or some spare time it never hurts to get it checked or just switch whats old anyways so its never a problem
Old Aug 27, 2011 | 06:43 PM
avt007's Avatar
Some cars seem to "lie" and show a mid range temp regardless of reality. BMWS are bad for this. You could confirm this if you know someone with a laptop OBDII reader. It displays actual water temp, not what your gauge shows.
Old Aug 27, 2011 | 09:02 PM
mohrd's Avatar
jagone, that's exactly what your gauge will read like. Most of us report just a tick under mid point all the time. Are you worried about or have any symptoms of overheating?
Old Aug 28, 2011 | 10:22 AM
jagone's Avatar
Default No Not worried
I was not all that worried about overheating as much as a thermostat or sensor that was bad, drove it 30 miles from the time I started it, it jumped up to a tick under halfway, with no issues, engine noise, computer shutting down ac, and it was an 80 degree day, so if it was going to happen it would have then. Just do not recall my other 2.5 doing that, but then the wife drove it more than I did.
Old Aug 28, 2011 | 01:54 PM
Gold_04_X-Type's Avatar
Good to see your X is acting completely normal.
Old Aug 28, 2011 | 01:55 PM
Jaggyx's Avatar
Mine always did this aswell...
Doug
Feb 27, 2019 01:31 AM
scooternva
19
Oct 27, 2015 02:14 PM
Philurusso
Sep 20, 2015 07:02 AM
twinstacks
Sep 19, 2015 01:09 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
