throttle body
Old Nov 6, 2012 | 09:22 PM
zez172's Avatar
Default throttle body
whats the safest way to clean a throttle body and is safe to move the door to clean behind it?
Old Nov 6, 2012 | 11:32 PM
Thermo's Avatar
Veteran: Navy
zez, cleaning the throttle body atleast for me is a non event. First off, go to the auto parts store and get your hands on some throttlebody cleaner (NOT!!!!! carb cleaner, completely different stuff). Now, go home and park the car. Let the motor cool. NOw, remove the air inlet to the throttlebody. YOu will probably want to also put a catch cloth under the throttlebody to catch anything that comes out the front of the throttlebody. THen using one hand, slowly open the butterfly valve and use the throttlebody cleaner to remove anything that is brown (should leave everything a nice silver color). Make sure to get the edge of the butterfly disk.
Once you can not remove anything more, re-install the intake. When you go to start the car, you may find it hard to start. Do not worry. YOu have essentially "flooded" the car. Crank the engine over and it will start. Of note, you may also get a code for misfires and/or running rich. Get the motor running and it will steady out.
rominempire
28
Oct 8, 2020 10:39 AM
RSpi
Mar 21, 2016 12:02 PM
xjrjag
Oct 12, 2015 03:16 PM
thedugger1
Sep 26, 2015 10:27 PM
