Tp sensor help!!! Please
Old Dec 7, 2013 | 07:52 PM
robiwhan's Avatar
Default Tp sensor help!!! Please
HI EVERYONE, i just performed a tune up on my xtype and after starting it up the powertrain light came on. car was ideling super high and when i put it in gear the gas pedel really wasnt working, im pretty sure this is a throttle bady sensor after the research online here. could this be?? could it be dirty sensors else where or any other issues im not thinking of?? any help would be a great help
Old Dec 7, 2013 | 07:58 PM
Thermo's Avatar
Veteran: Navy
robiwhan, get yourself a can of throttle body cleaner and spray the inside of the throttle body really good. If you see brown, wash it away. This will probably flood the car, so, when you go to start the car, place your foot flat on the floor with the gas pedal under your foot. This will clear the flooded engine condition and allow the car to start. Then lets see what you have at that point.
It may be possible that you simply have a bunch of gunk inside the throttle body and it is causing the butterfly valve to stick partially open, resulting in the high RPM and when you step on the gas pedal, nothing else to happen.
Oh yeah, make sure to spray the side of the butterfly valve (the thin edge). If any part of the throttle is going to stick, it will be that small area. Do not forget to spray where that edge will touch the throttle body. In short, if you can see brown, wash it away.
Old Dec 7, 2013 | 10:49 PM
robiwhan's Avatar
thanks thats what ill do tomorrow. i can see that the butterfly is dirty and the walls of the throttle body. ive found a used one online fairly cheap, should i take the chance to buy it?
Old Dec 8, 2013 | 09:10 AM
Alfadude's Avatar
seems odd that all of a sudden you have an issue like that after just having worked on the car. You might want to check that you haven't disturbed some wiring or loosened a connector when you were under the hood, especially if you didn't have the problem before. Just seems like too much of a coincidence. It is a good idea to clean the throttle body though. Hope you get it sorted quickly!
Old Dec 8, 2013 | 10:52 AM
robiwhan's Avatar
Default throttle sensor
thanks for the info if anyone has any other ideas.
symptons: idles really high, when in gear it moves but gas pedel doesnt work, power train warning light came on.
only work i performed was new spark plugs, ignition coils and accessory belt tensioner replacement.
Old Dec 8, 2013 | 11:01 AM
robiwhan's Avatar
and new o rings for the intake too.
Old Dec 8, 2013 | 05:20 PM
robiwhan's Avatar
Default Throttle position sensor
just writing this in hopes it may help someone else. cleaned throttle body really well and it seems to be running fine. ive ordered a used one for $100 and will hold it just incase. if all turns out well ill be happy to pass it on at cost. if anyone has any questions on the work I performed or troubleshooting to solve please ask and ill provide details.
spark plugs, coil packs, O-rings, belt tensioner, new headlight, throttle body cleaning..
Old Dec 9, 2013 | 03:40 PM
Thermo's Avatar
Veteran: Navy
Robiwhan, not to ask the silly question, but did you plug in both plugs for the throttle body? There is one for the TPS sensor and one for the throttle motor. The one for the TPS sensor is going to be the harder one to verify that it is made up.
Old Dec 9, 2013 | 08:46 PM
robiwhan's Avatar
yes I have. both are in good shape and clean and were connected up correctly when the problem started. the removal and cleaning of the throttle body was the easiest part of the day and your advice worked great. car is up and running well. as you already see ive a second throttle body and sensor on the way so if you come across anyone needing one cheap let me know.
Poet
Feb 7, 2025 02:18 PM
carl purchase
Oct 14, 2015 06:14 PM
Dave1109971
Sep 30, 2015 11:04 PM
Doug S
Sep 30, 2015 02:03 AM
