Transfer case oil change write-up now hosted
Old Jan 26, 2008 | 04:27 PM
Dennis's Avatar
ud
Default RE: Transfer case oil change write-up by Bojangles, now hosted
Well..Got around to doing my Transfercase lube change...(Note to self: Never assume anything Bo does is easy)
I only got about a cup of original lube out..I even jacked the car up on the right side (front and back alternately) to drain out all I could..
The Drain plug had a fair amount of metal sludge on it too, but nothing abnormal for 30,000 miles of wear.
I'm glad I checked and did it now, since it waslow and cruddy looking....Maybe a lot of the reasons people TC's are failing..Just a logical assumption.
I used Royal Purple...
Now I need a shower and hair degreasing
Old Apr 1, 2008 | 02:57 PM
ancientsanskrit's Avatar
FYI, Mercon V is not the correct trans fluid for the J-gate.
Good job guys! I would give this a go, but now that the car has an extra year of warranty, I dunno, perhaps later.
Old Apr 1, 2008 | 06:02 PM
  #28
bigdreams05's Avatar
Just went through all three pages and I must say that I'm impressed. Glad to see so many people getting on top of things and working on their transfer cases/transmissions. Great write up by bo and thanks ancient for hosting it. Thankszfmax for your info, and definitely hope you're working out the benefits of that friendship. LOL! J/k, nothing like a person that truly helps out their friends.
Old Jun 16, 2008 | 09:25 AM
Guys...I'm sure people are still using this. I'm probably going to lose my hosting space by the end of July (stupid school finally caught on that I graduated 2 years ago!!!). This is really great information, and I'd hate for someone looking for this information not be able to obtain it. Thus, I am wondering if we can get anyone else to host this file???
Thanks.
Old Jun 16, 2008 | 11:13 AM
  #30
jvegas's Avatar
what do you need to host.
Old Jul 20, 2008 | 09:21 PM
  #31
queenmb's Avatar
I cant seem to get this to open. I cant view the instructional demo. Am I doing something wrong?
Is this info somewhere else on the site?
Old Jul 20, 2008 | 09:29 PM
  #32
jvegas's Avatar
pm me your email address and i will send it to you. it is a power point program.
Old Jan 11, 2009 | 01:38 PM
  #33
Real_Tech's Avatar
If you notice in the power point photos the drain plug is actually more than 2 inches above the bottom of the T-case and the T-case also includes a sump that is not drained when this plug is removed. That is why the drain fill procedure in a Jaguar shop manual requires removal of the T-case. Not easy but thorough. The flush procedure should help get any old remaining oil from the case. Ideally you would want to remove all traces of oil and fill with the recommended amount through the fill hole on the top which is of course not accessable with the T-case installed.
Old Jan 11, 2009 | 03:13 PM
  #34
christo's Avatar
Hi Real_Tech I was wondering what you thought about the fluid for the tc? I found this brand and love their products?
http://www.amsoil.com/catalog.aspx?code=SVOQT-EA
Welcome to the forums..
Old Jan 11, 2009 | 03:23 PM
  #35
Dennis's Avatar
ud
And while you're at it RT..We have a never ending discussion about the ATF for the Auto tranny in the X..
So far these will work:
Royal Purple Multi-Spec
Valvoline MaxLife
Casatrol European car ATF
And maybe a few others...
BUT!, The Only problem in everyone of these fluids is the concern for compatiblility with what fluid JATCO has in it..
And at $45 to $55. per quart I will not use the Dealer supplied JATCO golden juice from the Gods..
Any input from you would be welcomed.
Old Jan 11, 2009 | 03:58 PM
  #36
Real_Tech's Avatar
I've always liked Amsoil products and use there oil in the Duck. I'm sure as long as the weights are compatible you wont have any problems.
Old Jan 11, 2009 | 04:05 PM
  #37
Real_Tech's Avatar
I always use the Jaguar Jatco pink watery fluid(dealer you know). I've seen 3 failed units that had Mercon V installed at independent shops. Not sure if there were existing problems before the Mercon was used though. I'm not familiar with any of the other fluids mentioned as far as actually being used. Back in '02 Jatco engineers were at the shop with a couple of test cars plumbed with about 20 different external pipes and gauges for access to internal pressure points and they were testing the compatibility and shift quality of other fluids in the Jatco box. We still use Jatco fluid if that means anything. Unfortunately I do not know of any other source than a Jaguar dealer unlike the 6 speed fluid which can be purchased at a Mercedes dealer for about $20 less than Jag prices.
Old Jan 11, 2009 | 04:09 PM
  #38
Dennis's Avatar
ud
Okay..Thanks..
I hope you are not a "filled for life" proponent..If you are, then we have nothing further to talk about..
Old Jan 11, 2009 | 05:31 PM
  #39
Real_Tech's Avatar
No, I'm more of a "filled till leaks" type of guy.
Just kidding though I do have a hard time getting customers to buy trans, diff or t-case fluid changes when the fluid alone is $400 at the dealer. Wish I knew a cheaper source for the fluids thatI could use at the dealer.
Old Jan 11, 2009 | 09:31 PM
  #40
McJaguar's Avatar
ORIGINAL: Real_Tech
okay, I'm probably missing something very obvious:
What's "the Duck"?
