Transfer Case Refill
Old Jul 7, 2012 | 08:56 PM
Niens2000's Avatar
Default Transfer Case Refill
Well guys it was a long hot week and I for one am happy it's over. I changed the Transfer case fluid the best I could. I tipped the car up on the passenger side as recommended to drain the old out, I got about half a cup. Being a 2002 I was suprised there was any in there. I tipped her up on the driver side, about 20-22 inches, for the refill and she took about 3/4 of a bottle of Royal Purple gear lube to top her off. Can anyone tell me if I put enough in? It didn't seem to want to take anymore and I squeezed the bottle as hard as I could. Should I repeat the excersize again in a couple weeks for a more thorough cleaning? Any advice would be appreciated. Oh yea, I wiped the plug off and got a good bit of sludge from it. Being magnetized I can only assume the "sludge" was actually metal dust. Thanks for any feedback.
Old Jul 7, 2012 | 10:38 PM
Thermo's Avatar
Veteran: Navy
If anything you over filled the transfer case. Bone dry it only takes 600 ml. If you put in 3/4 of a bottle, then you put in about 750 ml.
Old Jul 8, 2012 | 07:45 AM
Niens2000's Avatar
Thanks Thermo. Will it self vent or should I drain some out myself?
Old Jul 8, 2012 | 10:48 AM
Thermo's Avatar
Veteran: Navy
It will self vent, but plan on having a funky smell coming from the car. THe vent will drain right on to the exhaust pipe. So, for the next 2-3 weeks, you will have a funny smell coming from under the hood of the car and you may see a spot of fluid on the driveway where you park the car. Nothing that is earth shattering or leading to failure of your car. BUt, some people see this as a problem though too.
Old Jul 10, 2012 | 02:21 AM
Lioguar's Avatar
Hello Niens, just performed the transfer case drain and refill on my car.
750 ml shouldn't generate enough internal pressure in the TC to activate the overpressure valve, I personnaly put 700 ml (I planned to flush the TC changing fluid until it comes clear when draining, so I overfilled a little bit) without any issue.
Note: My transfer case was dry, we had to remove it from the car for another operation so draining was perfect.
EDIT: Checked under the car and had a look on my exhaust pipe, it appears that some oil was self-vented, so even 700 ml is too much. Didn't have any smell but I had a long travel on motorway just after oil was changed, I think oil was self-vented during the first kilometers.
Old Jul 10, 2012 | 04:36 PM
astromorg's Avatar
Before I established that 250mls are left in the box when draining through the drain plug, I was adding 550 mls. Having done this a number of times, it always blew oil out through the vent until a total of 625mls remained. Ie I was draining 375 mls. It gave the appearance of the righthand side oil seal leaking; very messy, very smelly!
JaguarLover101
48
Jun 12, 2023 10:28 AM
millertic
Sep 30, 2015 08:11 PM
Johnken
Sep 30, 2015 02:46 PM
dmatthewman
Sep 30, 2015 10:10 AM
