Transmission control module
Old Sep 28, 2016 | 04:20 AM
Napster's Avatar
Banned
Default Transmission control module
Hello.I have Jaguar X-type 3.0 2001.I need dump from 29F400BC labeled J306 module TCM 1X43-72401-BE JF506E automatic transaxle that I have error.Modulul error P1638 = EEPROM MCU = SAK-C167CR-LM and communicate with ECU by CAN.Thanks.
Old Sep 4, 2019 | 11:40 AM
dharry078's Avatar
Default Jaguar TCM
Did you resolve this?
I have a TCM that is unresponsive with corrupt data. Would wish to virginalize it.
Regards
Old Sep 4, 2019 | 04:18 PM
Dell Gailey's Avatar
From Brutal (a Jag Tech) =
"DO A HARD REBOOT YOU HAVE TO DISCHARGE THE CAPACITORS IN THE ECU (ALL ECUS, TCU, etc.) AND TO CORRECTLY DISCHARGE A CAPACITOR WHICH IS NOTHING MORE THAN A BATTERY YOU HAVE TO GIVE IT A PATH TO GROUND. TO DO THAT DISCONNECT THE NEGATIVE BATTERY TERMINAL FROM THE BATTERY AND MOMENTARILY TOUCH IT TO THE STILL CONNECTED POSITIVE, THIS GIVES ALL THE CAPACITORS A PATH TO GROUND AND WILL ERASE ALL VOLATILE MEMORY.(CK ENGINE LIGHT CODES ARE STORED IN NONVOLATILE SO THEY NO LONGER ERASE THIS WAY);
If this does not fix your problem, the TCU has failed and needs replacement. A VERY much smaller cause is a wiring harness failure (chaffed, broken).
Old Sep 4, 2019 | 04:47 PM
Additional post by Brutal =
"dont use sport mode for 300 miles, clear TCM adaptations with hard battery reboot, and there a proceedure to drive involving slow accels to different speeds followed by coasting to complete stops, and avoiding any aggressive driving and downshifting for a few hundred miles, etc."
Normal careful driving usually accomplishes this without the involved driving pattern.
Brutal
General Tech Help
Aug 23, 2019 06:35 AM
95Leaper
Sep 27, 2016 08:53 PM
03Xtype
May 16, 2016 09:57 PM
hafren
Aug 18, 2015 10:46 AM
