transmission oil cooler snap fittings
Old Apr 1, 2019 | 01:40 PM
Quatermass's Avatar
Default transmission oil cooler snap fittings
Hi,
I took my x type into an auto transmission shop today and came out with a quote for 500 quid plus vat! When i got home, I took the front valance off (which hadnt been off for years!) and started her up. The oil wasn't coming out of the oil cooler at all: there are two black hoses from the trans, with rusty ferrules on the end and black plastic quick fit connectors with tangs that engage on the aluminium ferrule. I'm sure you know about them!
Question: there is a small leak from the top connector which is causing all the grief. Can I disconnect it and replace an o ring inside (if there is one) or do I need a new hose? Any ideas as to how to repair would be greatly appreciated! I've tried reseating it and moving it slightly to no avail.
Old Apr 1, 2019 | 08:06 PM
Dell Gailey's Avatar
No o rings, you can cut, re-flare metal, use new TOC hose, after market clamps, or buy an easier New hose.
Old Apr 2, 2019 | 01:36 AM
Quatermass's Avatar
Hi Dell,
Many thanks for the advice. I had thought that would be the case. At least its not the 500 pound repair the garage had suggested! It makes me very angry when every garage you seem to go to here tries to rip you off! I'm going into town today to find some new hydraulic quality hose and clips and spend this afternoon with the sky filled with sump pans and springs!
Thanks again for taking the time to message.
Regards
Mark
Old Apr 2, 2019 | 08:35 AM
x_type_lpg's Avatar
I'm planning on doing a oil change by draining and filling while engine running by taking the feed pipe into a bucket while injecting the same quantity of new oil back into the return pipe. can you check if the top hose is the feed pipe or the return pipe.
Old Apr 2, 2019 | 10:40 AM
Quatermass's Avatar
On mine its the top hose for return, but make sure you follow the hoses up to the banjo bolts in case they are twisted on the way up!
Old Jun 30, 2020 | 12:45 PM
Bill400's Avatar
Default X-Type (X400) transmission fluid leak
Suspecting leaking transmission cooler fittings, I actually removed the O-rings from the fittings for inspection.
Finding no excessive free-play at the fittings and the O-rings in good, pliable, condition, dirt/grit was suspected.
Reassembled after thorough cleaning, the leaking persisted.
Dismounting the transmission cooler for a better view of the fittings revealed a corrosion induced crack in the aluminum pressure bypass valve body.
Note: the leak is apparent with the engine running.
As our X-Types age, unusual problems will occur.
mirisisa
Dec 18, 2019 09:13 AM
Qvhk
Jan 1, 2018 10:10 AM
Rustyxjc
Nov 26, 2017 10:06 AM
new mexico
May 22, 2017 09:43 PM
Roger95
Dec 16, 2015 09:09 AM
