Turn signals not working
Old Dec 3, 2017 | 11:05 AM
Bostonchad's Avatar
Default Turn signals not working
So last night my turn signals high beams and hazard lights stopped working I looked in the handbook and can’t find a fuse for this anyone else have this problem or know what it is? Is it save to say I need to replace the actual arm on the steering column?
Old Dec 3, 2017 | 10:16 PM
Thermo's Avatar
Veteran: Navy
Chad, it is possible that the plug for the turn signal stalk simply came unplugged. I would need to check the diagrams I have to see if there is anything else that is common to these 3 things.
Old Dec 4, 2017 | 05:36 AM
Bostonchad's Avatar
The trip button on the end still works I can press it to see mileage etc so I think it’s still plugged in but anything Controled by moving it (turn signal high beams) don’t work and the hazards button above the temperature control on dash won’t turn them on either. I’ve seen post saying about a bad Gem module but I would think anything controled by that would stop working correct?
Old Dec 4, 2017 | 11:42 AM
Bostonchad's Avatar
So I got it figured out threw an old thread it is fuse #25 in the box under the hood problem solved blinkers are working again.
Old Dec 4, 2017 | 01:08 PM
Thermo's Avatar
Veteran: Navy
Chad, good to hear. I was at work and didn't have the diagrams in front of me.
Old Dec 4, 2017 | 01:19 PM
Bostonchad's Avatar
It was a thred from 7yrs ago that you commented on for someone else so in a way you did help figure it out Thermo Thanks.
Old Dec 5, 2017 | 05:45 AM
Bostonchad's Avatar
I feel so stupid I double checked the handbook and fuse 25 is listed as “directional indicators “ I don’t know how I missed it oh well it’s fixed.
