Upgrade steering wheel
Old Apr 18, 2012 | 05:16 AM
Logotipo's Avatar
Unhappy Upgrade steering wheel
I have a 2003 x Type and it has the usual curling problem on the steering wheel center. I need help to know if it is possible to upgrade and install the latest model after 2004 without any changes. will it be just plug and play ? mine has just sound controls on the left side.
Old Apr 18, 2012 | 11:39 AM
Nardoswiss's Avatar
Have the same question.
Also thought about an S-type XJ steering wheel retrofit as they look and feel better.
I guess there should be nothing special to change to a new steering wheel.
Old Apr 18, 2012 | 02:39 PM
Aonsaithya's Avatar
Can you provide a more accurate description or a picture of the "usual curling issue"? The cover of the front of my steering wheel is seemingly "raised" from the rest of the steering wheel at the back edges, is that it?
Old Apr 18, 2012 | 03:08 PM
Nardoswiss's Avatar
Aonsaithya - yep. It's the curling problem.
Check this out
Old Apr 18, 2012 | 10:17 PM
Aonsaithya's Avatar
Ah, alright. Thanks!
So...is this just an aesthetic issue, or is there something wrong with the airbag itself?
Old Apr 18, 2012 | 11:50 PM
Nardoswiss's Avatar
There is nothing wrong with the airbag as I know. Just looks ugly + a "facelift" steering wheel feels a bit better. The control buttons are located in a more convenient zone + the rim is thicker...but looks ugly as well. LOL
I like this one
But quite unsure whether or not it will fit the X without problems. Huh. Maybe anyone knows the answer?
Old Apr 19, 2012 | 04:07 AM
Logotipo's Avatar
I like this one
What I want to know is if I can change the old steering wheel of my 2003 X Type with the curling problem and put the facelift one after 2004, will it fit ? is it just plug and play ? but it is not that one in the photo above.
Old Apr 19, 2012 | 07:34 AM
spielnicht's Avatar
Judging solely from these pictures, the physical mount seems to be the same, so the newer style steering "should" mount. However, the electrical connections probably are not the same. You would need to dig up the electrical schematics for the pre 2004.5 and compare them with the post 2004.5 schematics (available in the stickies). If you find out the connections are 1-1, which I highly doubt considering old has 8 functions vs 10 functions on new, good chance the connectors are the same. If not, you can then make your own custom harness, enabling you to just get the main features to work (airbag, horn, cruise, volume up/down and seek).
I don't have to tell you that messing with anything related to the airbag is scary dangerous and could cause injury or worse.
Also thought about S-type XJ steering wheel retrofit as they look and feel better.
Nope and nope, different mounts on each.
Old Apr 19, 2012 | 02:45 PM
Nardoswiss's Avatar
I do have 10 functions on my pre-facelift steering wheel.
Old Apr 19, 2012 | 10:59 PM
Aonsaithya's Avatar
It all depends on how you look at them:
  1. Radio channel/CD track +/-
  2. Jaguar Voice/radio mute
  3. Audio Mode
  4. Volume +/-
  5. Cruise control on/off
  6. Cruise control cancel
  7. Cruise control resume
  8. Cruise control +/-
If you consider the four rocker buttons each as two buttons (which is the actual case, technically), then there are 12 buttons.
I somehow like the button placing more on the pre-facelift than post, though.
Old Apr 20, 2012 | 12:47 AM
Nardoswiss's Avatar
It's the same when you count adjustable ways on your power seats .
Can you count the functions on "new" wheels?
P.S. I don't have a cruise on/off button on the cruise switch. It turns on by the "+" button and turned off by the "cancel" button. Huh
Old Apr 20, 2012 | 02:01 AM
mad_mike's Avatar
i would just love to get direction on where to buy the air bag cover or do have to buy the whole steering wheel?
Old Apr 20, 2012 | 09:21 AM
spielnicht's Avatar
I just found a pic that shows the seek and cruise on/off buttons on the side, didn't see those before. Your only option is to get your hands on the old schematics and check.
Just for reference, the new wheel has the following functions:
1. Volume Up
2. Volume Down
3. Seek Up
4. Seek Down
5. Start Voice Session/Mute
6. Source
7. Cruise Up
8. Cruise Down
9. Cruise Resume
10. Cruise Cancel
Old Wheel:
1. Cruise Resume
2. Cruise Up
3. Cruise Down
4. Cancel
5. Cruise On
6. Cruise Off
7. Start Voice Session
8. Volume Up
9. Volume Down
10. Select
11. Seek Up
12. Seek Down
I'm going on a limb and assuming the "Source" on the new has the same functionality as the "Select" on the old.
Old Apr 20, 2012 | 09:51 AM
spielnicht's Avatar
You can buy it separately. Your options are dealer ($$$$), eBay, or local junk yard.
X-Type Parts also stocks them. Good service, even from across the ocean.
http://www.xtypeparts.com/search.php?search=airbag
Old Apr 20, 2012 | 12:17 PM
Nardoswiss's Avatar
1. Volume Up
2. Volume Down
3. Seek Up
4. Seek Down
6. Source
7. Cruise Up
8. Cruise Down
9. Cruise Resume
10. Cruise Cancel
Old Wheel:
1. Cruise Resume
2. Cruise Up
3. Cruise Down
4. Cancel
5. Cruise On
6. Cruise Off
8. Volume Up
9. Volume Down
10. Select
11. Seek Up
12. Seek Down
Hey! Thx
I do not have the "Cruise On/off" buttons. So, as I mentioned - I have 10 function buttons. )
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
Burdedw
Sep 12, 2015 10:39 AM
1964Daimler
Sep 9, 2015 11:28 AM
