Upper Intake Manifold Gaskets
Old Jan 10, 2016 | 05:56 PM
USarmor's Avatar
Default Upper Intake Manifold Gaskets
Getting ready to do the 100K maintenance on my 2004 X-type.
Found these Fel-Pro Gaskets on Amazon for the upper intake manifold.
Amazon.com: Fel-Pro Ms96494 Plenum Gasket Set: Automotive Amazon.com: Fel-Pro Ms96494 Plenum Gasket Set: Automotive
Anyone have any experience with these, they appear to be a good deal?
- Brian
Old Jan 10, 2016 | 08:10 PM
avern1's Avatar
That's a good number for the upper gaskets and they should work fine. Be sure that the engine is cold when you start removals and use anti-sieze on the fasteners when you reassemble.
Old Jan 10, 2016 | 09:31 PM
Thermo's Avatar
Veteran: Navy
US armor, those gaskets will do the upper part of the intake. Those are the same ones I used on my car. Since you are in that far, might be a good time to do the lowers too. A few dollars more and take very little extra time to do. This will save you from having to worry about potential vacuum issues in the future. The PM I sent you has the info you need for the lowers.
Old Jan 11, 2016 | 02:50 AM
joesoap's Avatar
As Thermo says do lowers also,
I replaced upper and lower with Fel-Pro gaskets earlier this year on my 3.0l v6 and they are working fine.
Got them from Rock Auto worth a price check?
Lagonia
29
Nov 6, 2016 08:35 PM
RedXJ40
Jan 16, 2016 06:28 PM
odisyus
Jan 10, 2016 06:46 PM
sanchez
Jan 10, 2016 09:50 AM
seawind
Jan 8, 2016 06:14 PM
