Upper Radiator Hose is leaking, Help!
Old May 21, 2013 | 09:43 PM
pratajag's Avatar
Unhappy Upper Radiator Hose is leaking, Help!
Greetings everyone!
The upper radiator hose of my x-type 2003 3.0 L is leaking. Now the mechanic to took to said that when he removes the hose the plastic part that connects to the radiator could brake off then I will need to replace the radiator. What?
I am not working at the moment and I am freaking out to say the least. Is that true? A friend thinks I just need to replace the hose, can't know for sure until someone takes a good look at it and tries to take the hose, but I just want to make sure that this mechanic is not trying to give me the runaround.
Thanks for any help I can get on this.
Old May 22, 2013 | 08:18 AM
AlfaVeloce's Avatar
Well actually, I broke one myself. So it is quite possible. I broke off the smaller fitting next to the upper radiator hose. I also damaged the plastic tube on the engine side of the upper hose although I could have reused it if I had to. That plastic was very brittle it seems to me.
The hoses can sometimes bond onto the plastic fittings pretty aggressively and you have to be careful separating the hoses. Replacing the radiator is pretty involved, too. It will cost a good bit in labor alone, and the radiator is expensive anyway.
clubairth1
30
Sep 3, 2025 04:38 PM
Wahooesprit
Dec 23, 2019 02:01 PM
mhamilton
Sep 12, 2015 03:21 PM
1964Daimler
Sep 9, 2015 11:28 AM
